Originally Posted by bjl93
If i had a blown head gasket what are the symptoms?
Will the car over heat to 260......
Yeah......it very well may do this.
......or is it possible that the car wont overheat but it will reach temp quicker and fans are still able to bring down the temp.......
If you have a blown head gasket, it may not overhead. But.....
IF IT DOES overheat, the fans won't bring the heat down. Fans are just a component of a coolent system that works. If a blown gasket compromises the coolent system (radiator & coolent) then the fans won't....
CAN'T do the job by itself.
........My fans r constantly comming on at stop light's, and yeah only 1 fan turns on
Fans (
often just one, like Steve said) often have to come on when the engine is running but there's no air flowing over the radiator.
Now....what are your specific issues? They more info you give, the better folks here will be able to help you.
