distribitor help... asap.. thanks - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
Old 01-13-2013, 09:54 PM   #1
97z28convt's Avatar
97z28convt user's tech expertise is unknown at this point
Default distribitor help... asap.. thanks
So the last item for me to iron out on My lt1 build is the distributor. I was thinking msd.. then got told msd is crap.. then was thinking stock.. but gm only sells remans and they said those are crap. Since they are all 500 ish... Sounds like no good option.. My original distributor on has 55k on it and worls fine.. so i was just gonna do the msd cap n rotor..
97z28convt is offline
Old 01-13-2013, 10:11 PM   #2
yeah keep your original with an msd cap & rotor, and loctite the rotor screws
problem is, the key to a healthy opti is a mitsubishi optical sensor that isn't made anymore
still, reman GM opti is probably the highest quality one, followed closely by MSD
steveo is online now
Old 01-13-2013, 10:35 PM   #3
GearHead33's Avatar
GearHead33 user's tech expertise is unknown at this point
I have a TSP opti made by Terry Walters Performance Shop, it was only $130 but its been on there for almost a year and seems to work just fine. But these opti's are just a crap shoot.
'94 Trans Am A4; Custom CAI, J. Solomon Tune, Magnaflow cat back, TB bypass, TB Air Foil, Founders Performance PHB and Strut Tower Brace.
GearHead33 is offline
Old 01-13-2013, 11:14 PM   #4
any opti you buy in the $75-$150 price range is one of the new chinese clones that have been kicking around in ebay
they're sold under dozens of different names right now
not much is known about them to be honest. could be good, could be bad. really, there's only three things that should make an aftermarket opti a 'bad bet':
- poor sealing cases
- rotor screws that fly out
- poor quality optical sensor or poor timing wheel alignment
i wish someone would make a good aftermarket one; but it's an old engine platform. i think MSD will become the most popular option in the future.
Old 01-13-2013, 11:51 PM   #5
Stootz01 user's tech expertise is unknown at this point
If it only has 55k I'd say keep it also. I think the reason MSD gets a bad rap is because so many people actually buy them. No one writes reviews on how awesome there opti is, only when it takes a crap. Just like the original, when there are so many installed, there are going to be some bad apples. I've read that if your spinning under 7k there is no reason to spend the money. I personally bought one due to there warranty and their better rep then the other brands and have had no problems.
Stootz01 is online now
Old 01-13-2013, 11:59 PM   #6
there are other reasons to consider the msd...
aftermarket high output coils eat the stock cap up.. msd builds their wiring pigtail in (no plug); and msd provides an easy way to put a vented opti on earlier models, if you go gm, you're changing opti drive, timing cover, and all sorts of other stuff..
Old 01-14-2013, 07:41 AM   #7
MrCompton user's tech expertise is unknown at this point
I would go with the GM replacement myself. Had a 1998 S10 with 198k on the Vortec 4.3 I paid $400 for not running. Started replacing stuff with non-gm factory replacements and it wouldn't really run right. The two culprits, the cheapy ignition coil and distributor. Everything else cheap was fine, but I won't go cheap on that stuff on anything again.
I need some help, but at least I can admit it.
MrCompton is offline
Old 01-14-2013, 08:20 AM   #8
Roger Mabry's Avatar
Roger Mabry user's tech expertise is unknown at this point
Default Dynaspark opti
Mine has been on for a couple of years and works 100%. Rebuildable if you should have a problem down the road...not cheap but good quality.
Roger Mabry
Glendora, CA
1972 Jaguar XJ LT1/700R '94 Firebird, 52 MM TB, ported 2 1/2" Ram Horns, dual Magnaflows, A.I.R. delete, K&N cold air kit, EGR delete, Dynaspark, Meziere water pump and 4:09 positraction Sold for $5995.00 4/6/2013
1971 Jaguar XJ, 383/200R QJet, engine dyno @ 410 HP and 470 # TQ with 2:88 posi, dual Magnaflows and 2 1/2" ported Corvette Ram Horns
1974 Jaguar XJ 383/700R QJet, dual Magnaflows and 3:31 FOR SALE $3100.00
Roger Mabry is offline
Old 01-14-2013, 08:59 AM   #9
Another reason to consider msd is they will completely rebuild it for around $120 plus shipping. My msd is still working strong after 5 years.
cocobolo95 is online now
Old 01-14-2013, 10:23 AM   #10
Cracka Lacka Boom!
sweetbmxrider's Avatar
sweetbmxrider Tradesman Level Tech I
Never had an issue with my msd in the couple thousand miles its been on there. I hit 7k on my shifts too
sweetbmxrider is offline
Old 01-14-2013, 12:33 PM   #11
97z28convt's Avatar
And the debate continues... Seems like ya can go either way on this one .. I'm gonna stick with My plan and just grab cap n rotor... Time to place the order.. thx guys..
Old 01-14-2013, 07:56 PM   #12
USMC's Avatar
USMC user's tech expertise is unknown at this point
I have used MSD and was very very pleased after I installed it. Only problem with MSD is their quality assurance dept. It took three yep three MSD opti's to get a good one. However, I am super pleased. The thing that makes it interesting is they repair their opti's for less than a new one costs....if you manage to tear it up that is. East Coast performance can sell you one for $436 if you ask nicely. Inspect it before install and ensure its built the way it should be ( internally). It'll be worth it when you put it on. Oh and the reason I say check is that their internal timing adjuster is sometimes put together incorrectly. Best of luck
96 WS6..Ported stock intake w/58mm TB, 4bolt, 4340 SCAT RA/H-Beams/pistons, AFR195 Comp 58cc, ISKY Billet Steel 244/258 .600/.600, 1.5 CM Magnum RR, CM PR's, Bal W/I 1/2 gram w/1725 Bob Weight.http://www.youtube.com/watch?v=G-DpZpTcJaA
USMC is offline
Old 01-14-2013, 08:17 PM   #13
usmc_0811 user's tech expertise is unknown at this point
I used one from summit racing for my build, around 200-250 i believe, been on there for 5000+ miles, no problems yet
93' T/A- k&n CAI, msd 6al, cc503, 918 springs, pro mag 1.6rr, comp pushrods, comp lifters, lt headers, tf intake elbow, 58mm tb, a/c delete, lt4 intake manifold, pcmforless tune.
usmc_0811 is offline
Old 01-15-2013, 03:52 PM   #14
95 Firehawk's Avatar
Summit has the GM opti on clearance for $299 if that helps make up your mind.
Summit Racing - GM Performance Optispark Distributors
95 Firehawk is offline
Old 01-15-2013, 03:57 PM   #15
DUDBIRD113's Avatar
My msd is till going strong been running it for almost 7 months. The few times i thought it shit out on me turned out to be something else. Its a nice part for the money
DUDBIRD113 is offline
