01-10-2013, 12:28 PM
LT1 Power Steering Fitting
Any one know the fitting size on the high pressure out of the pump and then the other end of that hose fitting into the rack?
01-10-2013, 05:47 PM
Haven't checked the info for corectness, but from what I've found, M16 X 1.5 & M14 X 1.5 are the pump sizes. Should be same for rack, with rack having additional smaller fittings of M12 X 1.0
01-10-2013, 11:10 PM
Thanks Coco, thats what I had came across earlier, but it was not a good source.
01-11-2013, 08:07 AM
Manual rack
01-11-2013, 08:27 AM
Originally Posted by Mystery Bird
Manual rack
Street car.
01-11-2013, 08:00 PM
Street car.
Run skinnies in the front
01-11-2013, 08:06 PM
Street car that likes to see exit/entrance ramps at speeds greater than 10mph.
01-11-2013, 08:11 PM
Possible i rocked my slicks n skinnys during the summer. Take the exit easily at 50. I run nexen front tires too lol.
01-11-2013, 08:19 PM
Yea my race wheels have bias ply on them, not gonna DD on that kinda tire. NJ drivers scare me too much
And Coco, the rack side was a larger fitting than pump out let. I will try and find the correct size tmmr morning.
01-11-2013, 09:47 PM
tis be true
01-16-2013, 04:22 PM
Ok these fittings worked
AER-FBM2608 -6 AN to 16mm x 1.5 Male
AER-FBM2609 -6 AN to 18mm x 1.5 Male
Then I ran a hydraulic line to connect the two.
Technically, its not correct, as the JIC females are a looser class thread than the male -6an fittings, but it should be fine.
