What is the best Pulley system? - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
Old 01-01-2013, 08:06 PM   #1
Firehawkws6's Avatar
Firehawkws6 user's tech expertise is unknown at this point
Default What is the best Pulley system?
I bought the BBK aluminum underdrive pulley and placed it on the crank hub. Easy installation with the new belt, BUT...my voltage dropped when the car is at idle.
I've read on some previous posts that I may need the alternator overdrive pulley to compensate for the loss in voltage. I have also read that the horsepower gains aren't worth it and I should scrap it altogether. I'd hate to scrap this $65.00 pulley and I would love to gain whatever horsepower possible (even if it is small).
What is the best advice for keeping the pulley and fixing the voltage problem? Can the engine run safe with this low voltage? Advice is welcome, thanks!
1994 SLP Firehawk (#64) - Pacesetter Long Tube Headers, 3" exhaust w/o cats, SLP Loudmouth muffler, LT 4 intake, TPiS 58mm Throttle Body, 2400 stall, Granatelli MAF, 160 thermostat, and Morroso K & N CAI (removed the Ram Air box). 13.2 @ 102mph.
Firehawkws6 is offline
Old 01-02-2013, 08:16 AM   #2
Ditch it, try to recoup some money.
Old 01-02-2013, 08:26 AM   #3
Why ditch it?
Old 01-02-2013, 08:31 AM   #4
Racy Roadmaster Apprentice Level Tech II
It all depends how much voltage that you lost in your system. An old
NHRA stock and super stock class trick was to use a larger alternator
pulley on their cars,so the alternator would create less parasitic drag
on the overall system.So in theory it does work. I run a larger alternator
pulley on my Roadmaster LT1 (APPROX 15% UNDERDRIVE) without any problems. Also unless you are using an electric water pump you
will be underdriving your water pump also,which may be problematic in the summer. As far as engine HP goes,an underdrive pulley system isnt going
to give you more than a couple HP gain.ed
Racy Roadmaster is offline
Old 01-02-2013, 09:04 AM   #5
Originally Posted by Racy Roadmaster View Post
...Also unless you are using an electric water pump you will be underdriving your water pump also,which may be problematic in the summer....
you're definitely thinking of another engine
the lt1 uses a shaft drive waterpump, and will work the same regardless of whether the accessory belt is even on the car or not
definitely not affected by an underdrive pulley
Old 01-02-2013, 09:21 AM   #6
Im running a Chrome alternator from Jegs in my car 140 output, Tuff Stuff 8173NA Tuff Stuff Chrome Alternators
It should be fine with the underdrive pulley I think. The voltage drops from 13+ to a tad over 12. I just want to be safe and make sure it can handle that lack of charge.
Old 01-02-2013, 09:31 AM   #7
Jan 2, You are correct,I was thinking of a different engine. At least I got my mistake for the year overwith really fast! ed
Old 01-02-2013, 09:41 AM   #8
just being 12v at idle wouldn't concern me, the car will run, everything on your car is designed to operate with something like 11 to 15 VDC, but if it drops over a longer period of time at idle with electrical load you're asking for trouble.
so, be safe then; go start your car, put a voltmeter on it at the battery. turn your high beams and defroster on. run it for 5 minutes, check the battery voltage. run it for another 20 minutes, check again.
if it isn't holding stable @ 12 volts after 25 minutes, get that pulley off of there or you're asking for trouble
cranking batteries really dont like to be discharged past 12 volts on a constant basis with load put on them, it weakens them. if you really insist on running a car that's undercharging at idle, you'd better get a really nice deep cycle battery, like an optima.
Old 01-02-2013, 09:46 AM   #9
Thanks Stevo! Great idea, I'll give that shot and see what voltage I'm pulling after running a lot of components.
Old 01-02-2013, 10:40 AM   #10
Most underdrive pullies are designed to work with a higher idle. People don't realize this and have trouble. The piggy back one is completely worthless as far as performance goes.
Mystery Bird is offline
Old 01-02-2013, 11:50 PM   #11
Viper's Avatar
Viper Apprentice Level Tech I
None
Drivetrain Modifications #2
Mostly Stock.
Viper is online now
Old 01-06-2013, 09:25 AM   #12
bufmatmuslepants's Avatar
bufmatmuslepants Apprentice Level Tech III
Send a message via AIM to bufmatmuslepants
Ive been crucified for this before, but I dont even run a balancer, just the underdrive pulley bolted straight to the crank snout. Revs noticeably faster, if I hadnt gotten the pulley for free, I would have skipped it all together tho.
94 Z28 M6 hardtop power nothing LS1 lid, ported MAF, Pacesetter LT's, ORY, dump, 7/16 NSA Pro Mags, CSR EWP, Bilstein HDs, WS6 front springs, MSD opti, NGK TR55s, Taylor 8.2mm, B&M ripper shifter, underdrive pulley, Trifecta tune, LT4 KM, BMR rod ended LCAS, PR, and TA, UMI TA relo, 9" 4.33s spool, 12.39 at 111 1.67 60'
bufmatmuslepants is offline
Old 01-06-2013, 09:39 AM   #13
Well the only thing I can say is the balancer has a purpose,and at least
what I have read is that the balancer is supposed to help keep the
crankshaft from vibrating at higher RPMS and reduce harmonics.
If I were you ,I would keep a spare short block or at least a rotating assembly in your personal stock. ed
Old 01-06-2013, 09:43 AM   #14
Oh I know it has a purpose, it is to reduce harmonics. Im going to put it back on, but wanted every last hp for Street Stock class racing.
As far as charging issues, Ive never had a single one. From dailying in traffic, to long highway trips in 6th gear, never ever had any sort of charging issues.
Old 01-08-2013, 04:09 PM   #15
I increased the idle screw and she runs perfect now. Problem solved!
