Question Replaced optispark now wont start - Page 2 - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
Old 12-17-2012, 03:49 PM   #16
XtremeOracing's Avatar
XtremeOracing Apprentice Level Tech I
Originally Posted by 90rs View Post
the opti didnt just slide on but i didnt use fstners to put it on either, im not getting any spark at #1 cylinder and i have plenty of power. The car turns over fine it just doesnt fire. So I'm going to call up summit racing and tell them i need a new part, i believe its defective.
Yup i would do the same, but remember if it doesn't sit completly flush when you install it then you put it wrong! it shouldn't need to be forced in at all, it will sit flush with little to no effort when lined up properly.
1997 Z28 M6
Do | You | Want | Some | Slaw | ?
XtremeOracing is offline
Old 12-18-2012, 11:14 AM   #17
90rs user's tech expertise is unknown at this point
Pulled the 'new' opti today and sending it back to summit. Is this thing supposed to make a clicking/ gringing noise when it rotates? the one i pulled out didnt, maybe my problem. there no play in it either just the noise. Hopefully the new part comes in soon Summit is really good about shipping and recieving.
the video shows what I am talking about, sounds like its hitting lose metal tabs or something. Thoughts?
90rs is offline
Old 12-18-2012, 01:14 PM   #18
wdmickjr's Avatar
wdmickjr user's tech expertise is unknown at this point
yeah bad opti.. it should not make a noise. also when your new opti arrives, put a little thread sealant on the rotor's screws.
just off the wall question.. is this clunking sound in the same position on every rotation?
Disclaimer: This post may contain misspellings, grammatical errors, disorganized sentence structure, or may entirely lack a coherent theme. These elements are natural to the process of writing, and will only add to the overall beauty of the post.
Allez en avant, et la foi vous viendra
wdmickjr is offline
Old 12-18-2012, 01:31 PM   #19
on the rotors screws? And yes it makes it in the same place every rotation.
90rs is offline
Old 12-18-2012, 01:37 PM   #20
wdmickjr's Avatar
yes. remove the rotor's screws and place a small dab of loctite on the screws threads. and replace.
this will insure your rotor doesn't come off and this may be the sound you have.. maybe.
get a thread sealant that you will be able to remove later, in case you might want to replace cap and rotor later.
wdmickjr is offline
Old 12-18-2012, 01:45 PM   #21
just to make sure I follow ytour talking about opening it up from the front and you want me to put loctite on the rotors screw. Dually noted. Just shipped theyll get it thurs so I'm hoping for early next week to recieve it.
90rs is offline
Old 12-18-2012, 01:50 PM   #22
wdmickjr's Avatar
yeah. the cap and rotor parts are on the front. remove the cap and there is your rotor with 2 screws. it takes a special torx socket to open it up.
it is called an E4 socket.
OR you could do this:
http://www.lt1engines.com/tech/085-opti-cap-rotor-tool/
take well note of the O- ring gasket when re-installing cap.
wdmickjr is offline
Old 12-18-2012, 02:02 PM   #23
will do for sure thanks!! I'll let yall know when i get the part back in
90rs is offline
Old 12-19-2012, 05:20 PM   #24
USMC's Avatar
USMC user's tech expertise is unknown at this point
Or you could buy the MSD unit. They rebuild them for $120 when needed.
1996 T/A WS6.....in peices. Rebuilding with my son. It will be a 450hp DD. Anything is possible!
USMC is offline
Old 12-19-2012, 06:12 PM   #25
already payed for the summit racing unit and there replacing it no questions asked, thanks for the thought though!
90rs is offline
Old 12-26-2012, 02:21 PM   #26
jab251 user's tech expertise is unknown at this point
Originally Posted by DUDBIRD113 View Post
Cant get it to crank at all? Or when the motor turns it wont start. I installed my spline driving opti backwards before. Sounded like the timing was way off and would pop when it tried to start.
I have a 1997 camaro z28 and it wont start either. The motor will spin over and it pops a few times then just spins. Distrubter seems to be fine and fuel pressure and pump are good. Not sure what the deal is? Any suggestions? Could the timing chain have jumped time?
jab251 is offline
Old 12-26-2012, 03:03 PM   #27
Timing chain jumped time? That is highly unlikely. Have you done the Opti and Spark test from shoe's site?
4th Gen LT1 F-body Tech Articles
Do that and let us know how it goes!
1997 Z28 M6
Old 12-26-2012, 03:33 PM   #28
Workman's Avatar
Workman Apprentice Level Tech I
Yea man it does seem like it is the opti spark! Im thanking God I dont have to change mine! My 95 T/A has 110,800 miles on it and runs like a champ. Im hoping to not have ANY problems any time soon out of it. Let us know what happens with it man.
95 Trans am, LT1 V8 , Jasper Transmission A4, Throttle Body bypass, Removed spare tire+Jack, Installed ACR Bucket seats, 118k miles,
Workman is offline
Old 12-26-2012, 04:11 PM   #29
Racy Roadmaster Apprentice Level Tech II
Workman, Just to let you know any opti with over 100,000 miles on it
probably should be replaced. It should have at least a new cap and rotor
installed. I would be starting to look at a replacement opti or a Bailey system,an MSD or the 24 x system,thats probably the best one going. good luck and start getting prepared to school yourself on changing out your orig. opti. ed
Racy Roadmaster is offline
Old 12-26-2012, 05:46 PM   #30
DUDBIRD113's Avatar
I know when i put my opti in backwards (180 degrees out of time) that it would pop when cranking. Is it like a loud popping noise every 1/2 second or two?
DUDBIRD113 is offline
