Best Cam - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 8 (permalink) Old 11-17-2012, 07:57 PM Thread Starter
Best Cam
Im looking to put a mild cam in my 95 trans am next summer. What from your experiences is the best cam to use?
dkid22 is offline
post #2 of 8 (permalink) Old 11-17-2012, 07:58 PM
What kind of trans?
What kind of mods?
What kind of driving/racing etc?
How deep do you wanna go with it?
Etc.
post #3 of 8 (permalink) Old 11-17-2012, 09:24 PM Thread Starter
It is the lt1 engine an 4l60e trans. It has a 373 rear end an that's all. Its my daily driver now but soon it won't be. I want to be able to be competitive on.the track but able to drive it on the street. Idj how far ill go. I know I'm most likly gonna get new valves an all that as well
dkid22 is offline
post #4 of 8 (permalink) Old 11-18-2012, 12:58 AM
KW Baraka's Avatar
Why you getting new valves?
You gonna need new valve springs......and should probably get new roller rockers before new valves.
In any case.....the Comp Cams 503 would be a good choice if you port the heads.....the Crane Cams 845 will work well with stock heads.
IMHO, of course,
KW Baraka is offline
post #5 of 8 (permalink) Old 11-19-2012, 03:20 PM
Best bet dude, call an expert and have them custom grind one for you. They'll take all your info as far as current mods and future plans and turn that into a grind that is suited for your car versus an off the shelf cookie cutter. Lloyd Elliot specced mine and I couldn't be happier.
94 Formula, .224/.234 .561/.576 110 cam, 1.6 RR,LE2 Heads, AZ&M headers, 54mmTB, 3000 Stall. New Stall and spray coming. Tuned by gregrob.
rich5368 is offline
post #6 of 8 (permalink) Old 11-19-2012, 06:40 PM
Yo!
R3DLT1's Avatar
cc503 here on stock heads going 12.4 112!
R3DLT1 is offline
post #7 of 8 (permalink) Old 11-19-2012, 06:51 PM
Dynamic396's Avatar
I second (or maybe it's third by now...) the CC503 recommendation. Unless you're going to go nuts with it in the future, the 503 will give you some room to grow. It'll never be a crazy idling ground pounder, but it is a solid performing camshaft that will work well with stock heads, and then even better if you port them.
I use a custom grind that is very similar to the CC503 (I run it with a little tighter LSA) in many of the mild street engines that I build. It is a nice tame cam for use with most street mods.
Dynamic396 is offline
post #8 of 8 (permalink) Old 11-19-2012, 10:31 PM
Yo!
R3DLT1's Avatar
If i could go back i would go custom grind but oh well I'm more then happy with it.
R3DLT1 is offline
