11-09-2012, 03:56 PM
Break In Oil
Any suggestions on this topic?
Wanna prime the motor and toss it in soon.
11-09-2012, 04:07 PM
Standard organic oil. Like Castrol GTX.
If you decide to pop for specific break-in oil (which you probably don't need with a roller cam) let me know as I have 5 qts of Comp's stuff left over.
'68 Nova SS: Vortec 350 6 spd 4.11 Posi 9" DSE 4wdisc
11-10-2012, 07:28 AM
I use the Comp cams breakin oil for mine. I heard the Joe Gibb's is really good too.
11-10-2012, 08:33 AM
I always used Mobil 1 Clean 5000 non synthetic 10w-30.
Chris
The Few, The Proud, and the Crazy... LT1 owners
11-10-2012, 08:41 AM
Admin
Marvel Mystery oil here.
(kidding)
Use whatever dino oil you prefer and a non fram made filter.
Yep its slow.
11-10-2012, 01:54 PM
Ok sounds great, I will try and see if I may oil pressure tmmr evening if I can find a gauge.
11-10-2012, 03:01 PM
I would use a conventional fossil oil for the first 500 miles, only cause let the rings seat. And then use Amsoil with a filter designed for synthetic oil; Mobil 1 makes a good filter and there is WIX and NAPA.
My opinion and my opinion only.
'92 Astro CS with '95 fresh .030 4bolt 355 LT1, hand ported 374s & intake (David Vizard tech), 10.8:1cr, 1.94/1.5", 24x, 211/219* w/ 1.6" rr = .540/.549", '92 4L60 w/ '96 S10 torque converter, shift kit & corvette servo, G80 3:42.1, 255/70-15s, 2" front lift, poly bushings, Granny's Speed shop headers, 2 Cherry Bombs used for resonators, and 2 Thrush Turbo mufflers, 2001 LS1 pcm; local tune under an Oak tree.
4 year project/swap
aka fAstro
11-10-2012, 05:03 PM
Only the truck gets amsoil, the LT1 can deal with pennz plat.
11-11-2012, 10:50 AM
I'm with WildBilly. I prefer Castrol GTX. Run a petroleum oil for the first 500 miles and then switch to synthetic if you want.
As was stated, with a roller cam, it's not as critical as a flat tappet. You're mainly breaking in rings, and as long as a good plateau finish was put on the cylinder walls, a good set of moly rings will seat pretty much right away.
11-11-2012, 08:53 PM
Filled it up with 6qts of castrol, threw the drill on it, and got some interesting bubble noises.
Guess I gotta get a guage on it.
11-12-2012, 11:47 AM
Cracka Lacka Boom!
I have some lucas engine oil break in additive here.
