New to this board as my usual hangout has gone very quiet.
My 97 Trans Am started to have issues where I had to crank at times up to 30 secs before it would start.
I finally bought a fuel gauge and hooked it up at the Schrader valve after I could not get it going at all and the battery was low from the cranking.
With the battery still weak I put the ignition on and it showed no pressure. Tried one more time and it went up to about 10 - 12 psi. Another try showed 0 again.
Fully charged the battery, ignition on and no pressure. Tried to start and it fired for a brief second then died.
Ignition on and about 10 psi and the engine starts, pressure goes to 33 psi on idle. Take it for a spin. Cruising pressure 33-34 psi and WOT drops to 18 psi.
Back in the garage turned it off and then ignition on with 38 psi. Leaving the gauge on to see if and how quickly the pressure drops. After two hours pressure dropped to 0. Pulled the fuel rail off and with ignition I only get about 12 psi. Pressure dropped back to 0 eventually but no signs of leaking injectors.
Based on what I've been reading, looks like my fuel pump is not performing / on the way out and should be replaced or do I need to look at something else, fuel pressure regulator?
Appreciate you help.
Rene
Rene
