1993 Camaro LT1 wiring diagrams! - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 4 (permalink) Old 04-21-2012, 03:37 PM Thread Starter
shone190's Avatar
Smile 1993 Camaro LT1 wiring diagrams!
Hi everybody,
does anybody have PCM diagram (PCM connector terminal ends) for 1993 LT1 Camaro?
I'm, in the process of swapping LT1/T56 from 1993 Camaro into my 1988 GTA and I use complete wiring from Camaro, but have one problem. There is a few cutted wires that I need to connect to T56, but I don't have wiring diagram
I need wiring diagram for T56's Skip shift solenoid, reverse lockout solenoid, back lamp switch and speed sensor switch.
Thank You all in advance.
Best regards.
Corvette C4 LT1, Dodge Charger 1973, Golf 4 TDI 4Motion
shone190 is offline
post #2 of 4 (permalink) Old 04-21-2012, 05:18 PM
post #3 of 4 (permalink) Old 04-21-2012, 06:26 PM
If it will help you I have the 93 pcm pinouts and the pcm to component diagrams I can send you. If interested pm me with your e-mail address. I also have some other 93 stuff I can send you if you want.
post #4 of 4 (permalink) Old 04-21-2012, 10:39 PM Thread Starter
shone190's Avatar
Thanks a lot guys , cocobolo95, You have PM
shone190 is offline
