03-14-2012, 04:37 PM
Installing 1.6 roller rocker arms
I will be installing Crane Gold 1.6 ratio 3/8" self-aligning roller rockers on my LT1. It has all stock internals and has 130,000 miles. Do I need to change the valve springs or studs?
96 Camaro w/LT1, 4L60E rebuilt with 2500 stall, K&N CAI, Magnaflow catback, TPIS 52mm TB, 3.42 gears
03-14-2012, 07:58 PM
I wouldn't install 1.6 rockers without changing the valve springs. Some people don't change the springs and they get away with it but I wouldn't do it. Your 130k valve springs are worn out anyways. Last year I installed some LT4 valve springs and picked up 1 mph at the track with no other changes. My old springs had 117k on them.
1994 Trans Am, M6 hardtop, hotcam, SLP mids, S60 4.10
03-14-2012, 08:27 PM
^x2
03-14-2012, 10:57 PM
Admin
Originally Posted by shoebox
^x2
X3
I'm starting to feel like a broken record, I believe this is the second time I agreed with you on the same subject today.
Yep its slow.
03-15-2012, 07:49 AM
follow-up
So factory LT4 springs should work fine, any other spring recomendations? No one commented on the studs, so are the stock ones ok to stay with?
03-15-2012, 11:27 AM
Admin
Stock studs are 3/8" so they are fine and the LT4 springs will work fine.
Yep its slow.
03-15-2012, 08:18 PM
What are your goals for the project? If you plan on spinning over 6000 or plan on making horsepower swap out the 3/8 stud for 7/16. Run Non-self aligning rockers with hardened pushrods and guide plates.
03-15-2012, 10:46 PM
Originally Posted by Fox Slaughter
......If you plan on spinning over 6000 or plan on making horsepower swap out the 3/8 stud for 7/16. Run Non-self aligning rockers with hardened pushrods and guide plates.
Overkill for a stock cam.
Still.....if you decide to go that route.....drop me a PM because I got all that  !
03-16-2012, 04:06 PM
No cam in the near future. Probably just headers until its time to rebuild.
03-18-2012, 11:23 AM
I picked up over 50rwhp with a spring and rocker upgrade. My previous builder put cheap s.b.I springs in and i had majors valve train issues,12 broken damper springs to be exact lol. I went with the comp beehive springs and scorpion 1.6 s/a rockers. Kind of wish I had just bought a good n.s.a rocker and done guide plates cuz I like too rev my motors
93 z28 a4. 10.8@125 1.55 60' 150 shot.
le3 heads,xfi280 cam,strange adjustable shocks, adj. T/a,adj lower control arms,subfc's,10 bolt with 4.10's,stock 700r4 with transgo2&3 kit,hughes 3000 stall,nitrodave plate kit and much more
04-02-2012, 09:25 PM
can someone tell me the part number for the lt4 valve springs? i dont know if theres any difference between the years and i dont want to buy the wrong ones. right now ive got the pn 12495494 ready to buy
95 z28 a4, 3500lbs race weight, Moroso CAI, 1LE elbow, free mods, 1.6 nsa RR, 7/16 studs, guideplates, hardened pushrods, cutout after the cat. Current 1/4 mile:13.47 @ 102.56 mph Corrected time: 13.39 @ 103.65 mph Goal:12.5 with bolt-ons.
04-02-2012, 11:06 PM
Mostly Stock.
04-02-2012, 11:07 PM
Admin
That part # is fine, those are LT4 springs.
Yep its slow.
04-04-2012, 09:38 PM
I have a set that was run 2000 miles before a tear down for a 383 build. Won't fit in my iron heads. $80 shipped. All 16 with retainers and caps.
04-04-2012, 10:52 PM
#15
Spelling Bee winnah!
lol, god that sounds familiar. Same thing happened to me with dampers, destroyed my engine.
