96 lt1 master rebuild kits. engine code p - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 7 (permalink) Old 09-27-2011, 02:57 AM Thread Starter
Im having a little trouble finding an engine master rebuild kit for my 96 lt1 350.
i need one to come with the roller rockers and new camshaft also.
any suggestions??
Camaro1993 is offline
post #2 of 7 (permalink) Old 09-27-2011, 01:27 PM
Global Moderators
five7kid's Avatar
I've never seen a rebuild kit that comes with roller rockers. Cam kits, yes. But not an engine rebuild kit.
Most engine kits that have a cam just include a stock replacement type cam. You're better off getting the cam separately.
five7kid is offline
post #3 of 7 (permalink) Old 09-27-2011, 02:14 PM Thread Starter
sorry, i meant roller lifters
post #4 of 7 (permalink) Old 09-27-2011, 02:31 PM
"Lifters" are typically not included with a motor rebuild kit. Valve train parts (springs, roler rockers, lifters) are typically sold seperate.
I believe the "LT4 Hot Cam" kit has cam, springs & not sure about RR
the engine rebuild kit generally has rings, pistons, cam/rod/crank bearings and seal/gasket set and oil pump
BALLSS is online now
post #5 of 7 (permalink) Old 09-27-2011, 02:58 PM
Yes these guys are correct master rebuild kits do not include valve train components (cam,roller rockers,lifters, springs etc .) I have seen mostly rotating assemblies (crank,rods,pistons) and rings,bearings and seals with the master kits .
LE2 383 in progress....
pacesetter lt, trickflow RR,all arp hardware, scat crank,scat rods, trw pistons , 12:1 CR, lloyd elliot heads and intake work, custom LE cam, EWP,Ram HD clutch , 4.10 gears...... in process of shaving and smoothing engine bay YIKES
quickltz is offline
post #6 of 7 (permalink) Old 09-27-2011, 04:15 PM
skittle's Avatar
They are master "engine" rebuild kits. The heads are seperate from the engine so they are completely different kits.
1976 Datsun 280Z w/94 LT1, WC T5
http://www.youtube.com/watch?v=iITQN2Z6cRM
No F-bdoy for me , 1k pounds lighter 2x as fast
skittle is offline
post #7 of 7 (permalink) Old 09-27-2011, 04:26 PM
Member of over 500HP club
1963SS's Avatar
Not entirely true my friends. See below
All Parts AMERICAN Made!
OEM Engine Rebuild Kits - Chevy/GM
(upgrades may be available - please ask!)
Master Engine Kits
Include: Pistons, Rings, Gaskets, Cam Bearings, Rod Bearings, Main Bearings, Oil Pump, Freeze Plugs, Camshaft, Lifters, Pre-lube, and Timing Set, and Valley Pan (if applicable).
Chevy 350 5.7 (92-97) LT1 & LT4, Roller, 1pc Seal, Vin "P"
(Hypereutectic Pistons available for extra $59)
1. Specify if corvette for correct gaskets & timing.
2. Specify oil pump with 5/8" or 3/4" diameter inlet hole
1099-X 2,5 $279 $425 $632 HP Kit Avail
Click Here
$279 for re-ring kit
$425 for overhaul kit
$632 for master overhaul kit.
No valve springs but it does have lifters.
1963SS is offline
