93 Z28 Shutting Down - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 7 (permalink) Old 08-17-2011, 08:27 PM Thread Starter
My pops just picked up a clean 93 Z28 with 102,000 miles on it.Car has been great for the first few weeks,but now its developed a strange issue. i was driving it yesterday going about 35 mph in 3rd gear running roughly 2500 rpm and the car just shut off. When i say shut off i mean it didnt spit and sputter it just stopped accelarating. I pushed the clutch in and restarted the car and it started right up and all was well. About 6 miles later it did the same thing again,stopped accelarating pushed the clutch in and noticed it was dead,car restarted instantly and kept driving. It has done this twice now and im getting a little concerened. I dont believe its fuel related because if it was some sort of fuel issue i would believe it would sputter out vs. just cutting off like a switch had been thrown. Any sugestions where to start?? Thanks for any suggestions.
93zee28 is offline
post #2 of 7 (permalink) Old 08-19-2011, 10:11 PM Thread Starter
Any ideas guys?? anything??
93zee28 is offline
post #3 of 7 (permalink) Old 08-19-2011, 11:10 PM
95Z
Admin
I'd throw a fuel pressure gauge on it and see what happens to the pressure when it cuts out. A bad pump can do that.
Yep its slow.
95Z is offline
post #4 of 7 (permalink) Old 08-20-2011, 09:46 PM
have also seen ignition switches causing this problem not the key cylinder the switch located on the column try jiggling the key and see if car shuts off or stumbles
z28cam70 is offline
post #5 of 7 (permalink) Old 08-21-2011, 02:28 AM
BUTCHERZ28's Avatar
r u saying u bump started it while coasting or u put in the clutch and turn the key? is everything in the car losing power or just the engine?
94' Z28 engine build in progress. Home built 4L60E ~ K&N Cold Air, coolant bypass, air foil, MSD Optispark
00'Dodge Ram 2500 Cummins 24v Diesel. 100hp injectors, 8" stack, custom built a618 trans and converter, more to come.
BUTCHERZ28 is offline
post #6 of 7 (permalink) Old 08-23-2011, 07:02 PM Thread Starter
I put the clutch in and used the key...just the engine died,and when it restarts it fires right up as easy as normal.
93zee28 is offline
post #7 of 7 (permalink) Old 08-23-2011, 07:04 PM Thread Starter
gonna try the key jigling idea thanks for the tip cam
93zee28 is offline
