Rebuilt Motor Vibrating Bad - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 43 (permalink) Old 05-30-2011, 10:49 PM Thread Starter
E-money81's Avatar
Hey guys. My engine builder finally got done with the 383 install on my camaro. Unfortunately, the motor seems to be vibrating badly. The block and internals have been balanced at a local machine shop. They flywheel wasn't since it is stock and internally balance. I've also got poly motor mounts on the car. My builder says it could possibly be the mounts, but the vibration is so bad that he kind of doubts it. We plan to start with replacing the mounts back with the stock ones and if that's not it we plan on checking the flywheel. Worst case scenario it could possibly be the crank. BTW, the crank is a forged Eagle piece. Another interesting thing is that it seems the pulleys chewed up the serpentine belt and my said that might be due to the fact the balancer didn't seem to fit quite right. Any insight as to what the issue maybe would be greatly appreciated.
'96 Camaro Z28, 383 stroker, Crane Gold 1.6 rr's, M6 swap, 3.73 gears, Moroso CAI, BBK 58mm TB, Ported/Polished intake manifold, Ported/Polished stock heads, LE custom cam, LPP LT Headers, 32lb Accel injectors, Detroit Locker posi trac, Eibach lowering springs, torque arm bar.
E-money81 is offline
post #2 of 43 (permalink) Old 05-30-2011, 11:34 PM
stroker vibe
Check that balancer. If it didn't fit right it may have been damaged installing it. Next question why didn't the balancer fit right? Is it the old stock unit? Is it an aftermarket unit and is it compatible with the Eagle crank? If it is an older stock unit, they can get "spun" and really make an engine vibrate!
Good luck!
lakeratiam is offline
post #3 of 43 (permalink) Old 05-30-2011, 11:39 PM Thread Starter
E-money81's Avatar
As far as I know, it is the old stock unit. Why it didn't fit right I'm unsure about. I'd have to ask my builder more on that.
post #4 of 43 (permalink) Old 05-30-2011, 11:45 PM
See this thread.
lt1 balacing - LS1TECH
Psycho is offline
post #5 of 43 (permalink) Old 05-30-2011, 11:46 PM
While you are at it ask him to check and make sure that old stock balancer hasn't "spun".
post #6 of 43 (permalink) Old 05-31-2011, 01:59 AM
95Z
Admin
I'd be worried the flywheel is not correct.
If they balanced it w/o the flywheel did they assume it was a neutral balance one? If so and its a stock one they assumed wrong and you do in fact have a weight on it.
The stock LT1's have a weight (same size) on all flywheels and flexplates to help balance the assembly due to the removed material when the switched to the 1 piece rms.
Yep its slow.
95Z is offline
post #7 of 43 (permalink) Old 05-31-2011, 07:03 AM
Smile
Originally Posted by Psycho View Post
See this thread.
For anyone thats going to rebuild their LT1 now or in the future ,you should read this thread. I am pretty sure one of these guys are going to
balance my LT1, I DONT WANT TO HAVE TO DO THE JOB TWICE. ed
Racy Roadmaster is offline
post #8 of 43 (permalink) Old 05-31-2011, 07:07 AM
Laketrain, Can you define stock balancer hasn't spun,do you mean the outer ring may have moved in reference to the inner ring? thanks ed
post #9 of 43 (permalink) Old 05-31-2011, 07:54 AM
I went down to my toy box where I keep all the parts that I plan on using in my build and checked my flyhweel GM pn 14088765 and it has a big
honkin weight welded to it-externally balanced-. I was also wondering ,looks like there are only
3 holes in the flywheel to attach the torque converter to ,is that correct?
I believe the older ones had 6 holes. ed
post #10 of 43 (permalink) Old 05-31-2011, 08:22 AM Thread Starter
E-money81's Avatar
Well assuming it is the flywheel, what do I do at this point? Do I need to pull the flywheel and motor again and have the internals and flywheel balanced? Also, do I need to find a neutral balanced flexplate?
post #11 of 43 (permalink) Old 05-31-2011, 08:25 AM Thread Starter
E-money81's Avatar
I'm also not sure what a spun balancer means? What would a spun balancer look like?
post #12 of 43 (permalink) Old 05-31-2011, 08:40 AM
Lets wait until we get an official answer,my guess would be that the outer ring moved, where its attached by a rubber insulator, in relationship to the
inner part of the balancer. I think and remember its a guess,that the only way to tell if it moved would be if you had it marked by some type of paint line,but this would have to been done before it moved in the first place. ed
post #13 of 43 (permalink) Old 05-31-2011, 12:33 PM
95Z
Admin
I'd call up the shop that balanced it and ask exactly how they balanced it/what flywheel they want you to use. If they say stock (with weight), turn your attention to the damper on the front of the engine. If they say it needs a neutral balance flywheel you just need to get a new fly wheel with no weight on it and it should be fine.
Ed, yes the LT1 uses 3 bolts on the flexplate. It also has a different tooth count than the older ones.
Yep its slow.
95Z is offline
post #14 of 43 (permalink) Old 05-31-2011, 01:45 PM
The outer ring of the damper would have moved in relationship to the inner hub. It is virtually impossible to tell by looking at it. Sometimes you can actually see were the rubber and steel have separated or pulled. More than likely the flex plate/flywheel is incorrect. Just wanted to look at what I felt was an obvious point due to the mention of the damper not fitting right and the belt being damaged by the pulleys. But that could also be a alignment issue.
post #15 of 43 (permalink) Old 05-31-2011, 09:53 PM Thread Starter
E-money81's Avatar
Ok, today my builder spoke to the machinist that balanced the internals. He said the machinist balanced the crank using a stock flywheel and balancer. If that was the case then the crank should be balanced when it was put in my motor using the stock flywheel and balancer. I don't think the crank was balanced the way some people say that it should be, but in the end balanced is balanced.
Also, my builder explained to me some more about the balancer not being on the crank properly. He said there's a key way (or a notch in layman's terms) underneath the snout of the crank. He said for some reason, the balancer isn't fitting against the notch the way it should. He thinks thats probably the reason why my serpentine belt got shredded somewhat. He also seems to think I may not have an LT1 crank at all because he's never had an issue with the balancer not lining up the way it should.
