HELP!!! LT1 stalling? - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 2 (permalink) Old 03-22-2011, 05:45 PM Thread Starter
First off, Great site!
2nd off... Here's the sticky.
I just recently purchased a 94 Formula Firebird, LT1 T56.... great car, i love it with a passion.... it has a JASPER remanufactured crate engine Less than 5000 miles on it, cost over 8 grand to build. MSD optispark, Flowmaster headers, full flowmaster kit exhaust, lightened flywheel, lots of power, lots of noise, perfect. well kind of.... on 3 occasions now, its just died... like i turned off the ignition to it. the engine is about 3 years old since build, (former owner) and i dont' quite know what all parts are in this beast... when it stalls, it literally just turns off, no warning, but starts right back up, either via starter or popping the clutch. the Service Engine Soon light is on, and its throwing 4 codes. a LOW TPS Voltage code, a AIR system code, and 2 AC system codes (its disconnected). My guess is one of two problems... either a faulty MSD Optispark... note it was brand new during install... less than 5k miles... or a fuel pump relay... or some other ignition controled relay.... mabey getting too hot or failing somehow... if anyone has had this issue or has any ideas please please please shoot it to me... two of the times its stalled its done it while driving/cruizing. once it was during idle.
Thanks!!!! i have two other problem posts so please check them as well.
Gamikatsu is offline
post #2 of 2 (permalink) Old 03-22-2011, 07:37 PM
These cars have problems with the icm (ignition control module) failing when hot, but I don't think thats your problem, as when they cut off when hot, they usually take some time to cool off before engine will start again. I would look in the tps area, you have a code , low tps reading, and that could cut the engine off. If you could attach a scanner, obd1 type, the newer obd2 scanners won't read your car. Do a real time running scan while you drive and have an assistant scroll down the sensor list and pay particular attention to the tps. See what it does when the car shuts down. If it reads normal while running and voltage drops when car dies, theres your problem. If not you will have to check other areas. Go to www.shbox.com he has a wealth of lt1 info & testing procedures on his site. And may I suggest getting a GM factory repair manual. Indispensable.
