ignition control module???? - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 15 (permalink) Old 01-04-2011, 09:50 PM Thread Starter
ok so my opti went out so i put a new one in it got everything back together and it fired right up backed it out of the basement and let it idle for a minute and after about 30 secs it started sputtering and died the first thing that comes to my mind is the ignition control module any other ideas?????
1995 camaro z28 bbk underdrive pulley and k&n cai and air delete
xsvlt1 is offline
post #2 of 15 (permalink) Old 01-04-2011, 09:54 PM
Did it start back up?
Just a little lt1.....020 over speed pro pistons,comp custom cam,comp push rods,comp 1.6 rrs,and lifters,cnc stock ported heads,Walbro 255,edelbrock ported air gap intake,58mm t/b,pacesetter Lts,Summit 2.5 x-pipe with dynomax bullets,march underdrive pulleys,gm opti,msd cap and rotor,Msd 6AL,Moore 10mm race wires,SLP line lock,SLP fan switch,aluminum D/S,Built 4l60e,TCI 3,000 stall,B&M trans cooler3.73s,Edelbrock adjustable torque arm and Panard bar.more to come over the winter
my1994z28 is offline
post #3 of 15 (permalink) Old 01-04-2011, 09:56 PM Thread Starter
no it wont start
xsvlt1 is offline
post #4 of 15 (permalink) Old 01-04-2011, 10:07 PM
does it at least turn over?sputter or anything?
SLP lm 1,shift kit,volant ram air,MSD 6AL...UMI panhard rod and LCA's, SLP subframes and strut tower brace,eibach pro drop springs,drilled & slotted rotors, 02 Z06 wheels(gun metal),Brand new interior out of a 2000 SS...needs a dyno..
full bolt on and cam and recent 6 speed swap for A4.
94Ztwentylate is offline
post #5 of 15 (permalink) Old 01-04-2011, 10:12 PM Thread Starter
it turns over but it wont do anything
xsvlt1 is offline
post #6 of 15 (permalink) Old 01-04-2011, 10:13 PM
its possible,Do you hear the fuel pump with the key on?
post #7 of 15 (permalink) Old 01-04-2011, 10:45 PM
Have you checked the basics (spark and proper fuel pressure)?
post #8 of 15 (permalink) Old 01-04-2011, 10:54 PM Thread Starter
its getting plenty of fuel i havent pulled any plug wires off to check for spark yet im gonna do that first thing tommorow
xsvlt1 is offline
post #9 of 15 (permalink) Old 01-04-2011, 11:01 PM
I would also check and make sure that the opti harness is plugged in all the way,check the wires going to the ICM and Coil make sure they are plugged in as well.Did you use lock tite on the rotor screws?
post #10 of 15 (permalink) Old 01-04-2011, 11:23 PM
how old is the icm?..if its got good fuel pressure and the pump is working but it wont start than naturally its a spark problem...so that only leaves a few things...check the connections to the starter and battery to be safe and then the coil and opti harness also incase its flooded the the way to clear a flooded motor is to turn the igniton to the on position and hold the gas pedal to the floor for 5 to 10 seconds it should clear the flood..did you check for leaks after you put the wp back on?
post #11 of 15 (permalink) Old 01-05-2011, 04:46 PM
you don't need to pull plug wires; simply disconnect the coil from the opti and test for spark there. If you get spark there, reconnect and test a plug wire. If you then get no spark, the rotor probably fell off and grenaded the opti
torque_is_good is offline
post #12 of 15 (permalink) Old 01-05-2011, 09:32 PM Thread Starter
ok ive checked it all i have fuel pressure 40 psi i had the icm tested its good good strong spark at the coil but weaker spark at the end of the plug wires idk what else to check
xsvlt1 is offline
post #13 of 15 (permalink) Old 01-05-2011, 09:54 PM
i know its a b*tch but i pull the wp and open up the opti to make sure nothing grenaded like torque is good said.
post #14 of 15 (permalink) Old 01-06-2011, 08:59 PM Thread Starter
ok i took everything apart it all looked fine im taking a guess and saying the new distributor i got is bad so im gonna get another and try again
xsvlt1 is offline
post #15 of 15 (permalink) Old 01-06-2011, 11:55 PM
Make sure you use lock-tite on the rotor screws
