low oil pressure - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 9 (permalink) Old 04-04-2010, 07:47 PM Thread Starter
low oil pressure
i have a 1995 z28 camaro with 125,000 miles on it and it has low oil pressure when its hot it goes to like 20 to 10
1989fbody is offline
post #2 of 9 (permalink) Old 04-04-2010, 08:56 PM
Is that while driving or idling.
93 "Oddball" Camaro z28
philosophico is offline
post #3 of 9 (permalink) Old 04-04-2010, 09:18 PM
At idle thats pretty normal at normal operating temp. It actually says in the owners manual that oil pressure will range from 20 to 80 when warm.
97Trans-AM is offline
post #4 of 9 (permalink) Old 04-04-2010, 11:57 PM
plus don't forget factory gages are not an exact science when I checked mine with a mechanical gauge
stock gauge mech gauge
4 11-12
10 20
30 35
40 40
45 55
94 Z28: 383 12.5:1 forged 4340 crank, forged H beam rods, forged -5cc Mahle pistons, H series bearings all around, B&M flex plate, keyed hub, LE2 heads, custom LE grind, LE ported intake, BBK 58mm, LS7 lifters, comp hi-tech push rods, 1.6 nsa Pro mags, patriot golds, 42lb green tops, ARP bolts all around, canton 6qt pan, pacesetter coated long tubes backed by a magnaflow
93Z basically a car in a box...well three boxes ... one box down
camaroz28383 is offline
post #5 of 9 (permalink) Old 04-04-2010, 11:58 PM
perfectly normal at idle. my stock gauge reads 15 at idle and doesnt move past 40 at wot. i have a mechanical gauge to, and it reads 18-25 at hot idle, and 60+ at WOT. that is lower than most engines run but normal for an lt1.
1994 Z28 A4
Best ET 10.87 @ 123.66 - 1.49 60 ft - +1600 DA
Under the knife again... LE Victor EFI, Holley Dominator ECU, 13.5:1, E85, Custom SR
PA94Z is offline
post #6 of 9 (permalink) Old 04-05-2010, 09:29 AM Thread Starter
coll thanx guys
post #7 of 9 (permalink) Old 04-05-2010, 06:28 PM
Mine reads no lower then 20, and goes as high as 40 to 70 depending on rpm. This is fully hot.
As long as it doesnt read 20 and ur doing say 80 your fine, if it was that engine is prolly on its way out.
post #8 of 9 (permalink) Old 04-05-2010, 11:03 PM
Mine is anywhere from 18 to 25psi at hot idle. It just depends on the day the sensor wants to piss me off. About 2k to 3k it is at 40psi. Above that it is 60 to 70psi.
2fast4u88 is offline
post #9 of 9 (permalink) Old 04-05-2010, 11:20 PM
You might even try replacing the sensor. It is common for it to show lower oil pressure with age.
