03-16-2010, 07:41 AM
Building an 8000 rpm LT1
Hey guys i picked up an iron head LT1 out of a Buick Roadmaster i think, not sure of the year yet, i want to build it with forged internals and maybe bore and stroke it a little, first LT1 build so any helpful advice would be nice, i do not have a horsepower range in mind yet as i am just now planning it. i would like to turn about 7500, to 8000 if possible.
 2002 WS6
- 6.0, M6, 410 rear, LT's, magnaflow cat back, LS6 ported and polished stage 3 heads,LS6 intake,SLP 85 MM MAF, 85 mmTB, smooth bellows, 42 lb injectors, underdrive pulley,Walbro 90 PSI - 255 LPH F.P. CF air lid, K an N, TSP v2 cam, spec 3 clutch, heavy duty slave cylinder, race performer flywheel, MSD wires, Dyno tune,3 point SFC, UMI rear suspension, Drilled and Slotted Rotors, UMI ST brace other stuff i cant remember...lol
03-16-2010, 08:39 AM
The first thing that came to mind was the rpm restriction with a stock lt1 computer. The max you can have it tuned to is 7200-7250rpm. You're only choice would be a full stand alone engine mangement system. $$$$$
August 2010 Car of The Month (93 z28) March 2013 Car of The Month (94 z28)
03-16-2010, 08:52 AM
ok, thats one piece of info i can use, thanks man, any other tips on the internals?
 2002 WS6
03-16-2010, 09:01 AM
Use ARP bolts throughout. Get the mains splayed for 4 bolts. the stock crank and rods will do if you want to save some cash.
03-16-2010, 09:18 AM
To 8 Grand? Wheww... That's lean'n pretty hard on a lt1 bottom end I'd say.
03-16-2010, 10:04 AM
He can't go to 8000rpm with the stock computer. It's limited to 7200rpm. I have ARP bolts holding the stock crank and pink rods together. Mine buzzes to 7200rpm quite nicely.
03-16-2010, 10:20 AM
8 grand was just a number i threw out there, no biggie, i just want to build a bullet proof bottom end! should i keep the iron heads or go alluminum? either way i am going to have them redone.
 2002 WS6
03-16-2010, 10:23 AM
Either or... Most of the time iron heads are used for monster nitrous and/or turbo applications.
Callies Crank - Oliver Rods - Diamond pistons = bullet proof/$$$$
03-16-2010, 10:30 AM
I'm watching you....
The LT1 tables actually max out at 7000 rpm...but maybe with stock tach or shift extensions it appears more.
03-16-2010, 10:47 AM
My bad... PCMforless told me it was 7200.
03-16-2010, 10:51 AM
well a nice 355 or 350 fully forged build, fully balanced, could handle it deplending on cam and heads choice,
another thing that would help is a spark trigger since the opti could fail pretty easy at those rpms, also another ecu like a mega squirt to go cheap would be nice and easy to hold it down.. making it a map sensored instead of maf will increase high rpm range,
well basically its pretty doable but, not cheap, and also why so many rpms? jmmmm
Camaro from Guatemala
12.22@112mph on nittos 555rīs
03-16-2010, 10:52 AM
Cracka Lacka Boom!
what are you building for? i doubt stock heads and intake will like 7k. you are looking at 10k plus to build this correctly. probably more like 15k with a stout drivetrain.
03-16-2010, 11:00 AM
Exactly what I was thinking. a fully forged bullet proof motor is around $15k from start to finish.
03-16-2010, 11:13 AM
just want a groundpounder. it doesnt have to be 8grand, 7 grand is fine, i already turn 63oo on the stock bottom with 146,000 miles with no issues so 7 grand shouldnt be to hard to do, just dont want anything coming lose and breaking. havent really decided yet, still working on that, the old motor was only 200 bucks.
 2002 WS6
03-16-2010, 04:01 PM
#15
.......Callies Crank - Oliver Rods - Diamond pistons = bullet proof/$$$$
Bares repeating!!!!!
In any case, unless you're going with a solid roller cam/valvetrain, getting the engine to rev that high means you have absolutely no bottom end ( low RPM) HP or torque.
