03-18-2010, 05:10 AM
#31
thanks bro, i would think it will need a small bore as it has 146,ooo or so on it so it will need a little cleaning up im sure... and also i am no fast and furiouse driver..lol, but it is fun to hang the ass end out there and hear it wind up!
 2002 WS6
- 6.0, M6, 410 rear, LT's, magnaflow cat back, LS6 ported and polished stage 3 heads,LS6 intake,SLP 85 MM MAF, 85 mmTB, smooth bellows, 42 lb injectors, underdrive pulley,Walbro 90 PSI - 255 LPH F.P. CF air lid, K an N, TSP v2 cam, spec 3 clutch, heavy duty slave cylinder, race performer flywheel, MSD wires, Dyno tune,3 point SFC, UMI rear suspension, Drilled and Slotted Rotors, UMI ST brace other stuff i cant remember...lol
03-18-2010, 05:29 AM
#32
It might not need a bore. I tore my motor apart with 190,000 and there was no ridge in it at all, well it was .0005, gotta love gm light tension rings, at least they were good for something.
03-18-2010, 05:37 AM
#33
thats great, i am not sure what the iron head motor looks like yet,i hope its clean in there, my car is the one with the high miles, that motor will go in the garage and be built at a later date, money money money...lol
 2002 WS6
03-18-2010, 10:18 AM
#34
Cracka Lacka Boom!
Originally Posted by Edward-T
yea i know! a bunch of us down here like to go out at night and do some drifting at this abandoned factory down the road, just want a stout bottom end that wont fly apart, my car is not where it needs to be yet but it drifts fairly good, need more suspension and a stroger motor, possibly a better rear end as the 10 bolts are not that strong, but for now it is holding, so a 355 or a 396 or a stock bore with forged internals?? i am open to suggestions!
dude you aren't whippin around a vtec honda. get some low end torque and really let the rear loose
03-18-2010, 11:02 AM
#35
oh yea i know, trust me i hang it out, its mostly imports there, and a few stangs, me an a buddy (96 SS) go down and beat on them on occasion, lol!!!
 2002 WS6
03-18-2010, 11:39 AM
#36
Originally Posted by SlowAss94LT1
edit: (google is my friend)
"When we say that something "bears repeating" we are saying that it is important enough to say (or write) again, in the hope that the statement is understood by the audience. This would usually not be used in good quality formal writing"
05-15-2010, 11:14 AM
#37
Originally Posted by BLK WS6
The LT1 tables actually max out at 7000 rpm...but maybe with stock tach or shift extensions it appears more.
Are you sure about the 7K limit
My 355 uses the stock PCM with ED Wright tune and according to my datalogs it regulary spins above 7K rpm....
Maybe my datalogs are wrong?
As for the OP 7K shortblock is easy as for 8K I'd use a totally forged rotating assembly.....shortblock assembled and balanced by a (GOOD MACHINIST) and it won't be cheap....7K shortblock stock crank, forged rods and pistons....and once again balanced and assembled by a Good machinist will provide a reliable base for your engine.
However, the limiting factor of your build is going to be valve train....
Cheap, Fast, Reliable.......choose two....
Mike
1995 Corvette, AI 200CC heads, EM LTs, D44 w/3.45s, 3500vig, 58CC TB, Mez HD EWP etc.
05-15-2010, 12:57 PM
#38
What datalogging software are you using? I know Datamaster stops logging at ~6375 but the RPM line keeps going but doesn't tell you what it is.
Every LT1 OBDI PCM i've tinkered with the values stop at 7050. I've heard that OBDII can squeak past 7050.
Chris
The Few, The Proud, and the Crazy... LT1 owners
01-17-2013, 06:54 AM
#39
Sorry for resurrecting a dead thread.... If you're using data master selecting RPM16 will show RPM above 6375
Mike
02-05-2013, 05:15 PM
#40
only 2.7 years too late......................
02-06-2013, 07:24 PM
#41
Zombie thread....... Grnnnnnnndddd brains.....
Edward
02 Trans Am Firehawk #153
Arctic white on black leather
LS1 A4
You have a automatic, a dyno will only hurt feelings.
Go race your car
02-06-2013, 08:42 PM
#42
The first thing that came to mind was the rpm restriction with a stock lt1 computer. The max you can have it tuned to is 7200-7250rpm. You're only choice would be a full stand alone engine mangement system. $$$$$
Megasquirt.
300 bucks. Full stand alone fuel/spark.
