Oil Pressure Pegged at over 80 - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 14 (permalink) Old 03-10-2010, 10:30 PM Thread Starter
I just rebuilt my motor and now the oil pressure gauge is pegged at over 80. Tried grounding it out and it still stayed at 80. The one wire leading to the sending unit is still intact. Is it the gauge or the sending unit, and if its the gauge, how do I go about fixing that?
Miss Lindsey
1995 Trans Am Supercharged
Fastest Et with 50 shot: 12.28 @ 109 mph
W/O NOS: 13.42 @ 101 mph
MissLindsey is offline
post #2 of 14 (permalink) Old 03-11-2010, 01:34 AM
when you turn the car off does the gauge stay at 80?
if you unplug the sender whats it do?
camaroz28383 is offline
post #3 of 14 (permalink) Old 03-11-2010, 08:06 AM
That would cause the gauge to peg. That may be what is wrong (open circuit to sensor).
post #4 of 14 (permalink) Old 03-11-2010, 09:20 AM
If you just rebuilt the motor that's normal. Be happy to have oil pressure.
4Mesh is offline
post #5 of 14 (permalink) Old 03-11-2010, 10:29 AM
no thats not normal unless you built it to have that much pressure it should be readable on the factory gauge
post #6 of 14 (permalink) Old 03-11-2010, 11:26 AM Thread Starter
When I turn the car off, it goes down a little bit and reads somwhere around 80, instead of reading somehwhere in the 100's. When I unplug the sender, it still reads past 80.
Miss Lindsey
post #7 of 14 (permalink) Old 03-11-2010, 12:57 PM
BLK95TA's Avatar
IIRC when the Oil pressure sensor is unplugged, the gauge pegs. make sure the sensor is plugged in. on a 95 its behind the Intake manifold on the drivers side.
1995 Black TA A4 LT1
Mods: MSD cap and rotor, MSD wires, NGK plugs, K&N filter, 17" corvette GS replica's, Ram Air box and hood, 3.42 gears
BLK95TA is offline
post #8 of 14 (permalink) Old 03-11-2010, 01:38 PM
I'm not going to say his gauge is working properly, but what is shows is absolutely normal.
I purchased my car as a pre-order brand new in 93. This is EXACTLY what the gauge worked like since new. I've replaced the sending unit in the car two times in the years I've owned it. All of them were consistent. I just rebuilt my motor after my injectors leaked gasoline in to the oil and took out the bearings. After that, My injectors STILL leaked fuen in and my oil pressure is NOT as good as it was a month ago when I finished the rebuild. Ok, I can tell you that my gauge is NOT accurate, but it does tell the story.
This Post 94 camaro LT1 loses oil presssure shows a photo of MY Dash just a couple days ago after I changed my oil again and go the pressure back up where it should be. When the engine was freshly rebuilt and the oil was clean, it NEVER went more than one needle width below the 80 line, no matter how hot. It ran up to the stock high temp of like 230F, but since I had a new tune set the fans on lower. I don't know what temp they come on at but I think around 185. Whatever. My scan tool tells me the real temp and that's what I use if I really care.
Long story long... his oil pressure reading at 80 and pinned is not abnormal. My gas in the oil lowered mine and that is a fact. My motor with now 1000 miles on it has way less pressure than it did because of it and I know I've used up a lot of engine life with that mistake. I'll be tearing it back down for new bearings sooner than later.
With engine temp at 185F and 5W30 motor oil in the car, idling at 800 RPM's this is what mine looks like. And it was better than this when brand new, and with the new rebuild. If this is not normal, I don't know what to tell you folks.
When I start the engine cold, the needle is buried, way above the 80 line.
4Mesh is offline
post #9 of 14 (permalink) Old 03-11-2010, 01:49 PM
If you have the wrong sensor or it is unplugged it will peg. Not sure if you ground it out what will happen.
2fast4u88 is offline
post #10 of 14 (permalink) Old 03-11-2010, 01:58 PM
4mesh have you ever hooked up a mechanical gauge to see what it says? the dash gauge is electro magnetic, so any variation in resistance will change the reading on the dash. im not saying your gauge is wrong, but a lot of the time the dash gauge isnt accurate. at the same time it can still read variations in pressure. my dash gauge reads anywhere from 15-35 psi but my autometer reads up to 65 psi at wot and 25 psi at hot idle.
1994 Z28 A4
Best ET 10.87 @ 123.66 - 1.49 60 ft - +1600 DA
Under the knife again... LE Victor EFI, Holley Dominator ECU, 13.5:1, E85, Custom SR
PA94Z is offline
post #11 of 14 (permalink) Old 03-11-2010, 02:04 PM
I KNOW the gauge is not correct, I'm simply saying it's normal. Now, for you guys with sending units up top, this is absolutely not normal, but Mine and the OP's are not upstairs, they're down by the filter.
My real oil pressure WAS 65psi. That's where the ball relief in the Melling pump blows off. So, that was understandable. Now, after running more gas through my oil and bearings, it's not as high, but it's still ok.
When my gauge reads pinned, that's 65psi. A person could calibrate the gauge if they wanted using a potentiometer to set the thing, then read what it was and add that resistor value to the sending unit properly. I don't care what it is, as long as there is some!
4Mesh is offline
post #12 of 14 (permalink) Old 03-16-2010, 01:08 PM Thread Starter
Thanks everyone for the help. I just got around to it and i replaced the wire and it started working fine. Now I finally get to drive her again after 10 months!!!!!!!!
Miss Lindsey
post #13 of 14 (permalink) Old 06-29-2010, 06:22 PM
what wire did u chang mine is doing the same thing???
JEFFS Z28 is offline
post #14 of 14 (permalink) Old 06-29-2010, 10:54 PM
bym
bym's Avatar
allways on a new engine read your oil pressure with mecanical gauges, since you can crimp or the sensor could be working off from where your oil pressure is
when it pegs usually happens when you broke the sensor, when you did not plug it all the way in, or its not even conected
Camaro from Guatemala
12.22@112mph on nittos 555rīs
bym is offline
