water in my motor!!!!!!!!!!! - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 16 (permalink) Old 11-30-2009, 02:29 PM Thread Starter
well someone just came to look at the car and the first thing he did was pull the oil cap off and there was tons of white goop on it!!!!!!!!!!!!!!!!. so that meens there is water in the engine wright? it never happened before! i had the intake off a lil bit ago could it be the intake gasket leaking water into the engine? is that possible. PLEASE HELP i was gonna have the car sold and then this
95' A4 z28 hardtop w/ 355 SOLD....
blk01ws6 is offline
post #2 of 16 (permalink) Old 11-30-2009, 02:44 PM
Intake is dry, so no leakage there.
I would drain your oil and see if it all is sludge first.
post #3 of 16 (permalink) Old 11-30-2009, 03:25 PM
XtremeOracing's Avatar
Most probably blown headgasket ... sucks!
1997 Z28 M6
Do | You | Want | Some | Slaw | ?
XtremeOracing is offline
post #4 of 16 (permalink) Old 11-30-2009, 03:38 PM
Nickv96's Avatar
blk01ws6 Where are you located?
I'm from Minnesota and around this time of year if you run your car alot without actually driving it say 10 or more miles and shut it down before it actually warms up to operating temperature I have seen white sludge build up in my oil cap, not on my camaro cause I don't drive it in the winter but my SBC in my S10 does it and I don't have a blown head gasket. Also my 1987 Toyota 4 runner does this as well and it doesn't have a blown head gasket.
It's simply just condensation that never works its way out the PCV sytem.
Now if its all over and in your oil I'd say blown headgasket all the way.
1996 Z28-
Nickv96 is offline
post #5 of 16 (permalink) Old 11-30-2009, 03:40 PM
95Z
Admin
Could have gotten wet a lot of ways, but if its got the milkshake like substance in it chances are its a head gasket. You could always try draining and refilling and seeing if it will come back again, just keep a close eye on you oil pressure gauge.
Yep its slow.
95Z is offline
post #6 of 16 (permalink) Old 11-30-2009, 09:37 PM Thread Starter
im in Stockton California
i havnt touched the car yet, i got too pissed off im gonna drain the oil in the morning to see what it looks like......
i dont get it, i did a compression check about a month ago and and all the cylinders were between 178-180, they were all surprising close together. and since i did the compression check i havnt driven the car but maybe 10 blocks. i did start it for like ten minutes a day and then shut it off, so maybe something happened then....... also i smelled the oil dipstick and it reeks of fuel....... so fuel in the oil and white puss like stuff on the oil cap (and a lot off it). oh and the puss like stuff also smelled like fuel........
blk01ws6 is offline
post #7 of 16 (permalink) Old 11-30-2009, 10:01 PM
95Z
Admin
Tune could have been way off and washed the cylinders down, but I doubt it with that little cam.
I'd try changing the oil first before going to the "oh crap" scenario. If the car was sitting that long it could have just been moisture build up, 10 mins isn't long enough to get the car all the way up to temp.
Yep its slow.
95Z is offline
post #8 of 16 (permalink) Old 11-30-2009, 10:48 PM Thread Starter
i'll change the oil in the morning, how much driving or idling before that white goop stuff would start to appear on the cap again? guesstimation of course .............
ShowNoMercy when u said " intake is dry so no leakage there" that meant no coolant could get into the motor through the intake wright? just wanna clarify.....
the oil pressure is really high, almost pegged on start up (maybe 75psi) and the needle sits a little over halfway after the car is at operating temp. i was thinking high pressure was good?? is it?
ive noticed to get the car to operating temp it can take anywhere from 20-30 minutes even if its like 75-80* outside, is that normal?
thanks
blk01ws6 is offline
post #9 of 16 (permalink) Old 11-30-2009, 11:37 PM
Well the intake is dry. No coolant runs in it. That is what the steam pipe is for. If it doesn't overheat it doesn't have a blown head gasket more than likely. If it doesn't smoke white I doubt it is anything with a head gasket but could be. As that is the sign of a blown head gasket. Pull the driver side valve cover off and see what it looks like inside.
That goop can come from a motor drawing moisture. Heat drys up water. So with some heat if it isn't a gasket it should go away.
2fast4u88 is offline
post #10 of 16 (permalink) Old 11-30-2009, 11:51 PM Thread Starter
there is a little white smoke on start up but none after about ten to twenty seconds.........
i seafoamed it through the brake booster this morning so i wonder if that is where the fuel smell in the oil came from......idk...... i'll change the oil and drive it a bit and go from there.
blk01ws6 is offline
post #11 of 16 (permalink) Old 12-01-2009, 12:15 AM
That would be steam. I started up the car I just put together. After setting about a 3 hours in a heated body shop. And my y-pipe leaks pretty bad as I is rigged at the moment. But I got a puddle under the car pretty big from it dripping water out. But I don't have a leak though. It was just moisture built up.
The seafoam could have made its way around the rings and in the oil. When I seafoam a car. I do the motor first then drive around. Then do the oil. Because it breaks down oil. Which the way I see it you should change the oil after doing the motor as it will get past the rings.
post #12 of 16 (permalink) Old 12-01-2009, 02:48 PM Thread Starter
i just changed the oil and it looked ok, shinny gold. no white residue or milky look to it. but after i put in the new oil i started the car for like ten seconds and shut it off when i checked the oil again and the oil on the dipstick had a ton of tiny bubbles in it. does that meen anything? i never noticed it do that before..........
i took the oil filler neck off and stuck my fingers inside and rubbed around on the valve covers to see if there was any puss stuff on inside but there was none, it felt clean? so i dont know wat to think.....
also the oil pressure is really high, almost pegged on startup (maybe 75-78psi) is that good/bad?
blk01ws6 is offline
post #13 of 16 (permalink) Old 12-01-2009, 03:43 PM
Nickv96's Avatar
I still say its just some condensation thats building up and not completely getting moved out of the system because if you ran the car for only ten minutes at a time thats no where near enough time to get all the condesation out of it.
Just drive it for a half an hour let it cool all the way down and then see if it does it again.
The oil pressure is normal and these cars are known for inaccurate gauges anyhow.
1996 Z28-
Nickv96 is offline
post #14 of 16 (permalink) Old 12-01-2009, 05:24 PM
95Z
Admin
That oil pressure could be good or bad (more toward good though) because we don't know the specs on your engine. If its got a hv pump with high pressure spring in it and tight bearing clearances that could be low pressure (doubt it though).
I also just think it was condensation.
Yep its slow.
95Z is offline
post #15 of 16 (permalink) Old 12-02-2009, 01:20 PM Thread Starter
i posted a thread in the lounge "finally getting the car tuned" and some of the stuff i posted in there i thought might be relevant here. im really excited about getting it tuned but........ i just took the car out for a drive and i dont see a tune fixing everything thats wrong with the cars driving. the car has a very long hesitation when you give it gas, it takes a few seconds to react, then when it does, it doesnt even take off as much/fast as it should for the amount of gas its getting. when its in nuetral or park it seems to idle smoother than in drive or reverse, when you switch it out of park/nuetral to drive or reverse it bogs like its wants to dies, then it slowly comes back up to normal idle (faster if you rev it a lil) the wierd thing is it doesnt do the bogging thing at all when it first starts up (when the engines cold). it only does it when the car (engine) is warmed up. when the cars cold it switches between gear fine...... oh yeah and the oil pressure drops really low when the car does its bogging thing (like a lil below the 1/4 mark on the pressure gauge). On a coldstart the oil pressure is almost pegged, probably around 75psi, then during normal operating temp. the needle sits just above the 1/4 mark, isnt that low? the gas gauge also goes down really fast so i think the car is running REALLY rich, would the bigger intake valves cause the heads to dump to much fuel into the cylinders, kinda like bigger injectors? i appreciate any ideas/opinions guys, thanks
blk01ws6 is offline
