Urgent LT1 ENGINE SWAP IN AN 86 C10 - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 4 (permalink) Old 11-05-2009, 06:53 PM Thread Starter
emobile's Avatar
Exclamation LT1 ENGINE SWAP IN AN 86 C10
This is my first attempt at an lt1 engine swap. I have an 96 impala ss engine with all the wiring and components.(ecm, map sensor, etc..) I'm about to put it in a 86 chevy pick up. I would like any input on different kits available (if there is any!! I've looked) any advice on what to do about the pass key system. I've read you can disable this function when you reprogram the ecm. Also heard you could buy an eliminator kit for it. Also read about redoing my wiring harness so any schematic would be great! I'm trying to keep the a/c so i could use info on hooking that a/c compressor to the stock truck system. I know I have to relocate the a/c compressor up high due to clearance issues. I've read that I'll have to relocate the fuel lines also due to the year. (my lines come out on the passenger side) Any ideas on fuel pump and line setups! Read you can use a fuel pump from late 80's model early 90's throttle body setups. Also info for speed sensor.(Using the original tranny that came with the truck. Its been completely overhauled.) Ideas for the cooling fan setup and radiator. I know I'm asking alot but, I do appreciate all the advice I can get. Thanks again
Drive fast..... Take chances!!!!
emobile is offline
post #2 of 4 (permalink) Old 11-05-2009, 07:12 PM
Send a message via Yahoo to KenC
I never done lt1 swap with fi i turned it to a carb set up,you will need electric fans an u need impala,camaro trans am radiator or aftermarket rad with inlet and outlet in same area as those (reverse cooling),ur trans should bolt right up assuming it has a flexplate on the lt1.If i think of anything else ill let u know
KenC is offline
post #3 of 4 (permalink) Old 11-05-2009, 09:21 PM
just buy a "standalone" harness.. Then its just plug and play.. You can use the stock motor mounts, and use long tubes for that model truck.. Then buy a walbro pump, and adapt it into your fuel tank, and run your fuel line accordinlly
Forged 357 LE1 under the knife
Originally Posted by CraZ28 View Post
Sorry, that doesn't work on me! "I" am the voodoooer'!!!!
PANCHOLT1 is offline
post #4 of 4 (permalink) Old 11-05-2009, 10:10 PM
I like the idea i want to do it to a 68-71 c10 they are my favorite trucks,It shouldn't be difficult, wiring the most complicated
KenC is offline
