Low oil level sensor- need electrical diagram - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 16 (permalink) Old 08-13-2009, 07:36 PM Thread Starter
The low oil level light is on. I've tried putting a jumper in it, still on. So obviously I have a short somewhere.
Anyone have an electrical schematic that shows where this go's? I'd like to go ahead and just pull the wiring up, and solder a jumper up somewhere higher.
Thanks,
Chris
-Chris
'96 Formula- LT1 T56
'95 Regal- L82 4t60e
slick94prix is offline
post #2 of 16 (permalink) Old 08-13-2009, 07:50 PM
You have oil right?
The low oil light is just an idiot light, so if you get under your car and look above the oil drain plug you will see the sensor.
You can either just cut it out and bypass it, or test it for continuity and or replace the sensor.
post #3 of 16 (permalink) Old 08-13-2009, 07:57 PM Thread Starter
I've already put a jumper in the oil level plug, the light did not go out.
Yes, I have plenty of oil. In fact, just changed about 1 hour ago. The oil level sensor light has been on since I bought the car, just figured it was the sensor, until I tried jumping the plug for it and realized that the wiring for the sensor is actually at fault, and not the sensor.
-Chris
post #4 of 16 (permalink) Old 08-13-2009, 08:22 PM Thread Starter
I just cut the connector off, and tried about 6-8" up the line, using a good crimp (for testing), still nothing.
There's definately a short somewhere.
The only thing I've been able to find is that the brown wire go's to the Guage Cluster. The black/white stripe wire, no clue.
-Chris
post #5 of 16 (permalink) Old 08-13-2009, 08:35 PM Thread Starter
http://shbox.com/1/95_ta_cluster_pinout.jpg
Before I go and mess up my gauge cluster, I should just be able to jump the brown to the black/white right at the gauge cluster harness, correct?
I'm just wanting to get rid of this damn light, so it will also get rid of my Check Gauges light (without pulling the bulb)!
-Chris
post #6 of 16 (permalink) Old 08-13-2009, 08:44 PM
BrdwAtti2d's Avatar
Send a message via AIM to BrdwAtti2d Send a message via Yahoo to BrdwAtti2d
The low oil light is hard wired into the cluster. But I never got a check gauges light when the low oil light came on. My sensor went bad and I had to replace it.
Tracy
2002 L36 Firebird
1997 LT1 Firebird Formula (SOLD)
guys with stock throttle bodies have smaller orifices.
BrdwAtti2d is offline
post #7 of 16 (permalink) Old 08-13-2009, 09:21 PM
95Z
Admin
The wires for the sensor drop down from above and can hit on the exhaust mani and get burnt through. Just Another place to look for problems.
Yep its slow.
95Z is offline
post #8 of 16 (permalink) Old 08-13-2009, 09:57 PM
CKJ
Guest
Posts: n/a
I'd personally find out where it goes into the PCM at and do it maybe 6" from there. I can tell you which connector it goes in on a 95 but i'm not sure about the 96's.
It doesn't go into the PCM it just runs along the harness and runs into the 220 Connector which is the White one, the brown wire in slot C. The 220 connector is one of the connectors that hooks into your engine harness thats located underneath the passenger side kick panel. I would imagine that the other wire is just a ground.
post #9 of 16 (permalink) Old 08-13-2009, 10:11 PM Thread Starter
Yeah, I hadn't seen any place in the PCM for it for the 96-98 cars, so I figured it was more of a dummy light than anything. Just not sure how it tells the "Check Gauges" light to come on.
Will this plug/harness be on the inside of the car, plug through the firewall, or one of the plugs there in front of the PCM on the fenderwell?
-Chris
post #10 of 16 (permalink) Old 08-13-2009, 10:13 PM Thread Starter
Hmm... I wonder if the Check Gauges light isn't for the low oil, but for the abs/tcs lights that are on forever. I already have the TCS disabled in the pcm I just got back from solomon, but the ABS computer itself is bad, throughing up the ABS light (and I could care less about that).
-Chris
post #11 of 16 (permalink) Old 08-13-2009, 10:14 PM
CKJ
Guest
Posts: n/a
It'll be on the inside of the car. If you take off the passenger side kick panel (the long piece that runs along side the pass seat and stick your head under the dash you'll see 3 connectors together, a blue, white, and flat black one. Just make sure those are the ones coming from the firewall.
post #12 of 16 (permalink) Old 08-13-2009, 10:19 PM Thread Starter
Ok, good deal.
Probably won't get to it until sometime next week, so I can deal with the dummy lights for now.
-Chris
post #13 of 16 (permalink) Old 08-14-2009, 02:29 PM
If you check your oil regularly, why don;t you take the bulb out.
post #14 of 16 (permalink) Old 08-14-2009, 02:53 PM
BrdwAtti2d's Avatar
The blub is hard wired in the cluster in my car. I wanted to go that route when my sensor went bad since I had to disassemble the exhaust to the get stupid sensor changed.
Tracy
2002 L36 Firebird
post #15 of 16 (permalink) Old 08-14-2009, 03:39 PM
Toxicta's Avatar
May have missed this in the thread but have you checked the sensor itself. I seen one a few years back the the float piece broke. Causing the low oil light on steady. It still puts a smile on my face because instead of checking the dip stick the guy had added 3 quarts of oil and the light still wouldn't go out.
383, Forged Crank ,6" H-Beam Rods,Forged Wiesco Heavy Duty Flat Top Pistons,Lingenfelter Mechanical Roller Camshaft 236/244 .590/.590,Crane Solid Roller Lifters,Crane Gold Race Roller Rockers 1.6,Manley Severe Duty 2.02 1.60 Stainless Valves+.100 Ported Heads and PM intake. NOS Sportsman Direct Port Fogger System 240 HP Shot,Center Force Dual Friction Clutch,Auburn Posi Pro,Motive Gear 4.56,Boyd Coddington 20" Espadas,Nitto Invo 305/25ZR20,Nitto Invo 285/25/25ZR20
Toxicta is offline
