what would a bad ICM do?? - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 5 (permalink) Old 07-21-2009, 12:41 PM Thread Starter
What are the symptoms if your ICM is going bad?
steiger99 is offline
post #2 of 5 (permalink) Old 07-21-2009, 04:50 PM
No spark at all, missfires, etc.
Make sure it has a good ground and is cooled correctly
Autozone can test them, to a point.
1993 L32 v6 192,000 - GONE!
1996 LT1 v8 60,000 SLP ram air, !air, !egr, !evap, cc503, 1.6rr, pacesetter LT w/ORY, flow master 80, PerformaBuilt lvl 2, 3200 stall, 32# Red tops, Tune by Soloman
1997 LA1 v6 Venture Van!
syntax is offline
post #3 of 5 (permalink) Old 07-21-2009, 05:09 PM
Here's a few symtoms,
-car just won't start.
-suddenly dies, usually after engine is hot and most of the time will not start for several hours. What happens is over time for being exposed to high heat from being mounted right to the head. You can try using some sort of spacers to get it further away from engine.
Or when it dies try putting a bag of ice on it for about 5mins or so, it the ICM is bad it should fire right up.
But how many people actually carry around a little bag of ice with them.
Just a couple of ideas to think of
94 Z28 A4 55K
CAI, Shorty Headers, 2.75" Y-Pipes, 3" Cat Delete Pipe, 3" Cat Back, UMI Strut Brace, 2000 Stall TC, Alum DS, 3.73's, Front Brake Upgrade, TTS Datamaster, TunerCat, Custom Tuned PCM By Me & Solomon!
283HP&305TQ RWHP, Before tuning
309HP&361TQ RWHP, After PCM Custom tuned
+20% pwr loss A4=370HP&433TQ(FWHP)
NOT BAD HUH?
IT'S ALL IN THE PCM TUNING!!!!1
Previous Z28'S
-94 Z28 A4 (project car!)
-02 Z28 M6 (sold)
MY94ZZZ is offline
post #4 of 5 (permalink) Old 07-21-2009, 06:26 PM
OneShoe50's Avatar
Send a message via AIM to OneShoe50
Stays out late,
Steals money from mom and dad,
Doesn't pay attention in school,
Starts hanging out with a new crowd, usually Mustangs.........JK
Check to make sure you have good voltage to the PCM before you condemm it, check connections.
So you got a GOOD deal on a used LT1, there is no such thing as a good deal, dork!
1980 Camaro Z28, `95 LT1 rebuilt at Gramdma's Speed and Cycle Shop, 4L60E, 3.42, a little 2nd gen love...... CRT air foil and aluminum inlet elbow, 3" Hi Flow Cat and fake Flowmaster, Lingefelter CAI, ported MAF, Trifecta Performance tune, LT4 knock module, TechRods harness, Wallbro 255, no speedometer officer but I'll guess I was going too fast?.
OneShoe50 is offline
post #5 of 5 (permalink) Old 07-21-2009, 09:52 PM
When its completely bad, your car will not start period. Well mine didnt, and I had to have to it flat bedded home but mine kinda died in a weird way.
Oh and only replace it with a GM one, no autozone specials.
93 "Oddball" Camaro z28
philosophico is offline
