bad starter? - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 4 (permalink) Old 05-22-2009, 09:03 PM Thread Starter
bad starter?
hey guys I think my starter is gone or something else has gone bad. Anyways when I was hooking up my battery as soon as the negative terminal hits the battery the car trys to start. We are thinking that the solenoid in the starter is bad. What do you guys think?
1996 Pontiac Firebird Formula
T-56, SLP Cold Air Intake, Pacesetter Ceramic Coated Headers and Off Road Y-Pipe, Magnaflow Exhaust,Trick Flow Intake Elbow, Hurst Comp Plus Short Throw Shifter,Trifica 91+ Tune and lt4 Hot Cam Kit, Spec Stage 3 Clutch
1/8 Mile Time
8.82 at 82.13
1/4 Mile Time
13.564 at 104.22
96Formula6spd is offline
post #2 of 4 (permalink) Old 05-22-2009, 11:32 PM
I think you first need to check your starter wiring.
post #3 of 4 (permalink) Old 05-22-2009, 11:40 PM
Sounds like something is stuck in the starter, like the solenoid.
Red 1994 LT1 A4 Camaro Z28 hardtop SS clone, pacesetter mids, custom comp cam, 1.7rr, AFR 180cc heads, 3:73 gears, LS1 drive-shaft, 4000 stall. 375rwhp
NewOrleansLT1 is offline
post #4 of 4 (permalink) Old 05-23-2009, 12:29 AM Thread Starter
well tomorrow im going to jack up my bros 95 z28 and make sure the wiring is correct if that is not the case im going to change out the starter
1/8 Mile Time
8.82 at 82.13
1/4 Mile Time
13.564 at 104.22
