383 LT1 or LT1 .30 over? - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 58 (permalink) Old 04-27-2009, 05:34 PM Thread Starter
Question 383 LT1 or LT1 .30 over?
Hey guys, what would work better bang for the buck? My guy wants to spend around $3000-3500 on the build. Im thinking going .30 over with forged insides, AFR heads, and maybe the bottle. What do you guys think?
briank is offline
post #2 of 58 (permalink) Old 04-27-2009, 05:41 PM
James_Montigny's Avatar
Send a message via MSN to James_Montigny
For $3500, your best best is a quality Heads/Cam package from Lloyd Elliot or Advanced Induction.
There's absolutely no reason to put money into a stroker and try to run stock heads, you'll be very disappointed.
You can easily clear 400rwhp and pick up 11sec time slips with those setups.
(Been there, done that)
If your bottom end needs rebuilt and you can get away with pistons, go that route.
Your stock rods are already forged, their only real drawback are the stock rod bolts
which can't handle 6500+RPM without losing control of the bearings.
The stock crank is as strong (if not moreso) than any cast aftermarket offering.
What's wrong with the stock shortblock?
Parts For Sale --> http://www.ls1lt1.com/forum/showthre...187#post211187
James Montigny
1993 Pontiac Firehawk #018 - Forged 383, LE-Dart Heads and Hyd Cam
http://www.cardomain.com/ride/2297151
James_Montigny is offline
post #3 of 58 (permalink) Old 04-27-2009, 05:50 PM Thread Starter
There isent really anything wrong with it I dont think. It has 146,000 on it. So he wants to build it up. Would the 383 be the best way to go?
briank is offline
post #4 of 58 (permalink) Old 04-27-2009, 05:54 PM
95Z
Admin
Could you make more power with it? Yes
Could you stay on budget and still have a motor as tough as the 355? Probaly not
Yep its slow.
95Z is offline
post #5 of 58 (permalink) Old 04-27-2009, 05:56 PM Thread Starter
Ok. were is a good place to get a stroker kit? and a .40 over kit? so I can price them both out for him.
briank is offline
post #6 of 58 (permalink) Old 04-27-2009, 05:58 PM
95Z
Admin
Kits really aren't the best bargain and I'd never run a prebalanced one, but just google 383 stroker kit. All you need is a SBC setup with a 1 piece rear main.
Yep its slow.
95Z is offline
post #7 of 58 (permalink) Old 04-27-2009, 05:59 PM
SlowAss94LT1's Avatar
Send a message via AIM to SlowAss94LT1
^^^^ good info.
I am looking into a 355 build myself, and would like to spray 150 at it all day with no problems. This will be a winter project, but I want to do my homework and do this all right the first time. Would you say to use the stock crank and rods for a nitrous application along with some forged pistons? What bearings and bolts would actually hold together to 7000rpm?
August 2010 Car of The Month (93 z28)
March 2013 Car of The Month (94 z28)
SlowAss94LT1 is offline
post #8 of 58 (permalink) Old 04-27-2009, 06:01 PM Thread Starter
This is the only im looking at telling him about if he wanted to do a 383:
http://cgi.ebay.com/SB-CHEVY-383-LT1...3A1%7C294%3A50
and go with the:
MAHLE DISHED pistons 10.5:1 with a 58 cc head
And im going to do total seal rings for sure.
And then I think a set of Dark or AFR heads with the 58 CC, and then call up comp and have a custom grind done for this.
Then headers
How about that?
briank is offline
post #9 of 58 (permalink) Old 04-27-2009, 06:07 PM
95Z
Admin
and go with the:
Then headers
How about that?
I'm glad you understand the importance of heads! Most people we get want to build a budget 383 and stick stock heads back onto it and its impossible to change their mind. However, ported stockers by LE or AI will flow at least as good as the aftermarket heads (LT1 castings have huge potential) so you might want to look into that just as another option, I'm not sure what the new heads are going to run you, but ported stockers might save you a few $$$.
Everything looks good on that kit with the exception of the crank. That will def be the weak link in that setup.
Yep its slow.
95Z is offline
post #10 of 58 (permalink) Old 04-27-2009, 06:11 PM Thread Starter
Yeah, this isent my first engine build lol. I know that heads and cam will make or brake your set up. I dont like not haveing a forged crank but I havent found one that has that. I know the stock heads have alot left in them but they are so heavy lol. I sold him on doing aftermarket heads, I LOVE AFR heads, I would like to do a 210 heads but would I have to move to a LT4 intake or how good is the LT1 intake?
briank is offline
post #11 of 58 (permalink) Old 04-27-2009, 06:15 PM
95Z
Admin
A ported LT1 intake will easily support it. The LT4 actually won't work right b/c the runners are .1" higher so they only work with the LT4 heads.
Is this an iron headed engine? Also what is it going in?
Yep its slow.
95Z is offline
post #12 of 58 (permalink) Old 04-27-2009, 06:17 PM
Do a leak-down test on the stock shortblock to see if the rings are in good shape.
If it comes back good, you can save yourself money by leaving it alone.
As mentioned above, the extra displacement is a waste without a good top end to compliment it.
Callies makes an excellent kit at a reasonable price. But expect to spend $2000-2400 on a forged rotating assembly alone.
(as I mentioned above, no reason to go cast)
I used an Eagle forged assembly for my 383 build, the parts along cost $1850.
Either way, you'll also need bearings, fluids, gaskets, balancing labor ($175+) and precision assembly.
That will erode your entire budget very quickly.
James Montigny
post #13 of 58 (permalink) Old 04-27-2009, 06:23 PM Thread Starter
Ok here looks like a killer deal! Thanks for taking the time to go tho everything
It looks like this is a 383 kit with fully forged crank and pistions:
http://www.strokerkits.com/index.php...emart&Itemid=1
Then Item number:
1-41829
Forged Dish pistions.
I would like to see 10.5:1 CR
briank is offline
post #14 of 58 (permalink) Old 04-27-2009, 06:27 PM Thread Starter
ITs going in a 95 Vette. ITs a cast iron headed engine. The guy will spend more if its worth it. Im going for the 383 becasue it seems like thats going to get him were he wants. Mid 11's or low 11's.
On that site I posted it looks like its $1275.00 full forged.
It will have a good top end tho. AFR,Dart, Trick Flow heads somthing on that line and its going to have a pretty good size cam.
briank is offline
post #15 of 58 (permalink) Old 04-27-2009, 06:31 PM
95Z
Admin
Hmm, did the motor get swapped, all vettes and F-bodies are suppose to have aluminum heads in them...
Looks like a good kit, but no brand or anything. You know you can run 11.8:1 on an LT1 with pump gas right? Reverse flow cooling
Yep its slow.
95Z is offline
