firing order - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 19 (permalink) Old 06-26-2008, 10:25 AM Thread Starter
firing order
What is the firing order for the left and the right side of the cap on a 1997 firebird formula. Also I did a opti switch and plugs this weekend, now my car went from dying to just have a bad miss. Do you think that my opti pigtail could be bad?
LT1 Chevelle is offline
post #2 of 19 (permalink) Old 06-26-2008, 10:56 AM
DJ_Kovacs's Avatar
drivers side from top to bottom: 5,3,7,1
pass. side from top to bottom : 4,6,8,2.
Engine firing order is 1,8,4,3,6,5,7,2
before blaming anything else, make sure your wires are on right, and try it then go from there
Let us know
DJ_Kovacs is offline
post #3 of 19 (permalink) Old 06-26-2008, 11:20 AM
BrdwAtti2d's Avatar
Send a message via AIM to BrdwAtti2d Send a message via Yahoo to BrdwAtti2d
Ummm those cylinders are out of order for an LT1 ^ Firing order is right. Make sure you got the opti indexed properly too, it's easy to miss the place where the peg is suppose to go.
Tracy
2002 L36 Firebird
1997 LT1 Firebird Formula (SOLD)
guys with stock throttle bodies have smaller orifices.
BrdwAtti2d is offline
post #4 of 19 (permalink) Old 06-26-2008, 12:20 PM
DJ_Kovacs's Avatar
How is it out of order
Looking at your diagram, which is from shoebox's website, my description is bang on. Am I missing something here?
I did the same on my LT1, and she runs on all 8 cylinders, so I dont know man
post #5 of 19 (permalink) Old 06-26-2008, 12:38 PM
BrdwAtti2d's Avatar
Doh! Sorry my mistake, I thought you were giving him the cylinder order on the block. I reread your post and saw the err of my ways. My apologies.
Tracy
2002 L36 Firebird
post #6 of 19 (permalink) Old 06-26-2008, 12:39 PM
DJ_Kovacs's Avatar
If your talking about cylinder layout, which I think you are, then the layout is:
drivers front to back 1,3,5,7
pass front to back 2,4,6,8
but this is NOT what the O/P was asking, he was asking about the opti terminal layout, which I answered
post #7 of 19 (permalink) Old 06-26-2008, 12:40 PM
DJ_Kovacs's Avatar
Thats cool
post #8 of 19 (permalink) Old 06-26-2008, 03:25 PM Thread Starter
what do you mean by indexed? I thought there was only one way the opti could go in. I am pretty sure everything is hooked up correctly, not sure why I have a bad misfire now.
post #9 of 19 (permalink) Old 06-26-2008, 03:47 PM
BrdwAtti2d's Avatar
If you accidentally drop the key on the camshaft into one of the cloverleaf things on the back of the opti, the opti will go on but the indexing is all screwed up.
Tracy
2002 L36 Firebird
post #10 of 19 (permalink) Old 06-26-2008, 04:03 PM Thread Starter
i know that i put that in the right spot.
post #11 of 19 (permalink) Old 06-26-2008, 05:58 PM
...said by many a person...
Hopefully, you're correct.
post #12 of 19 (permalink) Old 06-26-2008, 08:11 PM
keenan's Avatar
I also said it & i'll be damn come to find out it wasn't in the right hole if i was a betting man i'da lost it all .
Krazy Kajun 95 camaro 383 LTI A4 ,58mm Edelbrock TB,3.73gears,Descreened MAF, Trans go shift kit,4000 stall,b&m cooler,K&Ncai,Tune from Trifecta Performance , LT Headers,CSR water pump.Stage 3 P&P Heads ,Comp. Cams XFI 292 ,1.6 RR's.
keenan is offline
post #13 of 19 (permalink) Old 06-26-2008, 10:58 PM Thread Starter
I focused hard on putting it in right. Matter of fact I checked it twice, too make sure. Who knows i am only human. I have been doing most of my own mechanic work so I think it is time for a mechanic. I have this motor and combo in a 71 chevelle. Do you think that the opti pigtail could be bad. Also can I throw off the timing by turning the opti once it is in?
post #14 of 19 (permalink) Old 06-27-2008, 06:56 AM
BrdwAtti2d's Avatar
Yea the harness could be bad. You shouldn't be able to turn the opti once it's in.
Tracy
2002 L36 Firebird
post #15 of 19 (permalink) Old 06-27-2008, 10:17 AM
DJ_Kovacs's Avatar
^^ exactly, if you can turn the opti when installed on the motor, you would be turning the whole motor as well, highly unlikely. If it turns without much resistance, you got some issues my friend. Check to make sure nothing is broken in that timing cover
