radiator hoses - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 7 (permalink) Old 02-13-2008, 11:52 PM Thread Starter
radiator hoses
ok dumb question but thought I would ask, does it matter which hose goes to the top and which goes to the bottom? Its a 96 LT1 cause it would be a lot easier in my car if I could do it "backwards"
the owl is offline
post #2 of 7 (permalink) Old 02-14-2008, 10:37 AM
Send a message via AIM to ss.slp.ls1
The way you worded the question is a little confusing. If you mean keeping the same locations on the water pump and changing the orientation on the radiator, don't do it! I wouldn't mess with the cooling system design, I'm assuming its made that way for a reason. If you mean swapping hoses all together but keeping the same configuration, then sure it will work, but why would you need to?
"When you are knowledgeable about all aspects of your rebuilding project, it will likely succeed with flying colors."
"If you don't know that it's right, presume it isn't."
1999 Chevrolet Camaro SS, M6, K&N FIPK CAI, Mangaflow Cat-back
1997 Chevrolet Camaro SS, M6, Flowmaster Cat-back
Project: LQ4 build-up in progress
ss.slp.ls1 is offline
post #3 of 7 (permalink) Old 02-14-2008, 04:44 PM
CKJ
Guest
Posts: n/a
Its best to put the radiator hoses back the way they came off (i guess thats what your asking..?)
post #4 of 7 (permalink) Old 02-14-2008, 07:36 PM Thread Starter
I have the LT1 in a 93 rx7 so I don't know how it came lol. Right now I have the upper one on the water pump going to the upper on the radiator (which is on the opposite side) and the lower on the radiator going to the lower on the motor. It runs fine, but would be easier if I could swap them and someone said I could but I don't trust them too much. can the upper on the motor go to the lower on the radiator and vis versa?
Sorry for being confusing it is hard to word lol
the owl is offline
post #5 of 7 (permalink) Old 02-14-2008, 08:12 PM
You're talking about changing the flow through the radiator. So I would have to say no. Rubber hoses are cheap, and they come in all kinds of pre-made forms. Go to the store and pick out some hoses that will work for your application, but in the stock configuration.
post #6 of 7 (permalink) Old 02-14-2008, 08:23 PM Thread Starter
yeah my hoses work, they just are crammed with the intake and such. I am just trying to verify what someone told me.
the owl is offline
post #7 of 7 (permalink) Old 02-14-2008, 08:47 PM
CKJ
Guest
Posts: n/a
Thermostat line is always at the top. Return always at the bottom.
