PCV valve hose cracked - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 11 (permalink) Old 02-11-2008, 04:17 PM Thread Starter
Scott Anderson's Avatar
On the driver side where it connects to the intake is broken. I had a slight vacuum leak and when I went to find it I made it worse. Now it's basically not connectable. I'm going to go to VatoZone to get a hose elbow connector for it.
What will this being like this do? Should I not drive it at all or what? Also is this what's causing my cam-like lope at idle when warm? I assume so, since it's the only vacuum leak I had... that i could hear at least.
97 Trans Am LT1
Nothing compared to the LSx/L67/VQ... NOTHING.
00 YZF-R6
It'll run 10s, but a stock LS1 could take it... EASY.
Scott Anderson is offline
post #2 of 11 (permalink) Old 02-11-2008, 04:35 PM
DJ_Kovacs's Avatar
Just buy the same diameter hose, you will be fine, I had to do the same a few years back. As far as the lope at idle when warm, The vacuum leak could probably be the culprit, or a sticky EGR valve. Do the PCV valve first, if it doesnt go away move to the egr, and so on
You *shouldnt* cause any problems to drive like that for a little while, but I would get it fixed sooner rather then later
DJ_Kovacs is offline
post #3 of 11 (permalink) Old 02-11-2008, 05:22 PM
you will be fine it will idol higher though.
440 rwhp trans am is offline
post #4 of 11 (permalink) Old 02-11-2008, 05:46 PM Thread Starter
Ok, thanks. Also, I don't think it matters, but the hose isn't cracked as I said in the title, it's an elbow hose connector that the previous owner must have put on it.
97 Trans Am LT1
00 YZF-R6
post #5 of 11 (permalink) Old 02-11-2008, 08:12 PM
CKJ
Guest
Posts: n/a
The hose going to the TB from the passanger side valve cover is one solid piece of rubber except for the 90 Degree elbow sitting in the valve cover gromet. I bought a brand new one from GM being that no other hose is going to fit as nice as the OEM style.
post #6 of 11 (permalink) Old 02-11-2008, 09:07 PM
DJ_Kovacs's Avatar
Maybe I mis-read, I thought he was talking about the pcv valve hose, on the intake, which you can get anywhere, the hose from the pass. valve cover, to t/b, thats a different story, probably GM like you say
post #7 of 11 (permalink) Old 02-11-2008, 09:37 PM
CKJ
Guest
Posts: n/a
Nope...i actually misread! I just jumped the gun and ASSumed that he was talking about the famous hose on the TB that always breaks.
But you were right Mr. Kovacs, a piece of prob 3/8's hose bent to a 90 degree to connect to the steel line will do the trick. My apologies to you
post #8 of 11 (permalink) Old 02-11-2008, 09:42 PM
DJ_Kovacs's Avatar
No Prob Chris
While on the subject of the infamous breaking hose,, roughly how much did you spend on yours, because i'm evidently plagued by the same problem.
post #9 of 11 (permalink) Old 02-11-2008, 09:56 PM
CKJ
Guest
Posts: n/a
I couldn't even tell you if you had a gun pointed to my head. I can get a part number and look it up on GMpartsdirect for you.
post #10 of 11 (permalink) Old 02-11-2008, 10:03 PM
DJ_Kovacs's Avatar
Dont worry about it, Just thought you knew, i'll look it up, no rush.
Thats the least of my worries right now. After I get all this mess of parts back to a functioning LT1 I will cross that bridge then. What started as a "winter tune up" turned into a full on H/C swap... At least thats what I told my Wife
post #11 of 11 (permalink) Old 02-11-2008, 10:04 PM
CKJ
Guest
Posts: n/a
TB to valve cover pipe GM # 10128365
Gm Parts direct says $7.40, which usually I can get at my local dealership for lets say...3-5% more than GM parts direct, but I don't have to pay their rediciolous shipping charges in return.
