oil pressure prob? - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 16 (permalink) Old 02-08-2008, 03:12 PM Thread Starter
afroman794's Avatar
oil pressure prob?
95z. 136k mi. auto
im driving to the dr. and notice my check gauges light is on and my oil pressure is fluctuating from the red line to just above it. now ive never had any problems w/ oil pressure before. but after the dr. it was fine.
it only would drop at stop lights. so i put it in neutral and kept it at like ~900rpms so it would keep pressure. now i dont beat on it so i dont think its a spun bearing, the engine isnt making any noises it shudnt be making.
and when i got home i checked my oil level thinking maybe i had a leak develop and my oil level is fine, but there were a few little air bubbles on the dip stick.
is this my sump pump going or do you think its something more serious??
thank you for any and all input
sex should be just like a honda, slow, obscene, and loud enough for the neighbors to hear
Cause the LT1 is superior to the LS1? Seems simple to me.
afroman794 is offline
post #2 of 16 (permalink) Old 02-08-2008, 05:39 PM
CKJ
Guest
Posts: n/a
Define "it only would drop at stop lights" Is that in the process of putting on brakes or, only at a low idle in gear. I've heard that if your oil pressure dropped that low while applying brakes then your pickup tube has fallen off.
post #3 of 16 (permalink) Old 02-08-2008, 05:44 PM Thread Starter
afroman794's Avatar
no i can hit the brakes while driving its only at idle it drops. after i saw it happen twice i started putting it in neutral and holding the gas at 1k rpm and it was fine. but if i let the engine idle it would flutter around 1-5psi
im hoping the pump is just worn out and not something more serious
post #4 of 16 (permalink) Old 02-08-2008, 05:47 PM
andrew ws6's Avatar
I had a oil pump pickup tube come off of my Monte SS and it had oil pressure at low rpms and barely any at cruise rpm but i heard it when it came off the tube and the crank went halh a round and the crank won but also spun a bearing in about a 3 mile ride back home. I would put a manual gauge on it and check it that way first.
96 T/A 355,m6,cc503,pacesetter lts,52mm tb,1.6rr trifecta tune,!cats,!air,!egr,3.73's
87 Monte Carlo SS LT1 swap in progress
andrew ws6 is offline
post #5 of 16 (permalink) Old 02-08-2008, 05:51 PM
andrew ws6's Avatar
Also check your oil filter, afriend of mine had the inside of one collapse on a pick-up and do the about the same thing.
post #6 of 16 (permalink) Old 02-08-2008, 07:23 PM Thread Starter
afroman794's Avatar
thanks ill take a look at it tomorrow morning
post #7 of 16 (permalink) Old 02-10-2008, 06:38 PM
Replace the oil pressure sending unit?
Garrett TX LT1 is offline
post #8 of 16 (permalink) Old 02-10-2008, 06:47 PM Thread Starter
afroman794's Avatar
if the new pump doesnt solve the prob ill try that
post #9 of 16 (permalink) Old 02-10-2008, 06:55 PM
mtperformance's Avatar
I am willing to bet you got a bearing going out in your lower end ,if you have metal shavings in your oil when you do the pump then you know you have a project ahead off you.
mtperformance is offline
post #10 of 16 (permalink) Old 02-10-2008, 06:59 PM Thread Starter
afroman794's Avatar
yeah ive got it parked until i get a chance to check it out.
im preying its just the pump
and just curious what makes you think its a bearing instead of just a pump?
post #11 of 16 (permalink) Old 02-10-2008, 07:00 PM
03slowZ06's Avatar
This is not always true. When I ported my intake I thought I cleaned up really well. How ever next oil change I had shiny oil. I was freaking out. Pressure was still good so I the oil and crossed my fingers. 1 year later still good to go.
u can do it
03slowZ06 is offline
post #12 of 16 (permalink) Old 02-10-2008, 08:16 PM
That all ways seem to be the case after some porting or engine rebuild but if you are loosing oil pressure all of the sudden and you got the ultra cool glitter lube then usually that only means one thing . For afroman794 I hope I am way off ,but somebody had to bring it up.
post #13 of 16 (permalink) Old 02-11-2008, 08:53 AM
03slowZ06's Avatar
No you made a very valid point. He needs to do these checks and post up results.
u can do it
post #14 of 16 (permalink) Old 02-11-2008, 12:37 PM
lt1firem6's Avatar
Send a message via AIM to lt1firem6
I hope you figure it out cause my girlfriends 89 ta is doing the same thing at cruise it will hold a good 30psi but as soon as you come to a dead stop it goes to zero pick up I am hoping
1996 T/A m6 under construction for ground up rebuild
1986 s-10 my daily driver,soon to be LT-1 powered (dead)
1998 s10 singlecab shortbed 4.3 auto,CAI,descreened maf,throttle restrictor delete,mobil 1 syn
lt1firem6 is offline
post #15 of 16 (permalink) Old 02-11-2008, 01:05 PM Thread Starter
afroman794's Avatar
yeah thursday is my day off so ill check it out then, and let everyone know.
