I CHANGED MY WATERPUMP AND I NOW HAVE A OIL LEAK - Page 2 - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #16 of 26 (permalink) Old 01-11-2008, 10:45 PM
mtperformance's Avatar
I am almost positive that my 97 LT1 had an o ring on the shaft for the water pump but you guys are probably right .
mtperformance is offline
post #17 of 26 (permalink) Old 01-11-2008, 10:58 PM
CKJ
Guest
Posts: n/a
You are right, there are two o-rings on the wp assembly. But it holds no oil, just keeps dirt out of the hard grease.
seal on WP = 92-95 LT1 - 12553792 96-97 LT1 - 10128329
seal on drive = 92-95 LT1 - 12553792 96-97 LT1 - 12553792
post #18 of 26 (permalink) Old 01-11-2008, 11:21 PM
So I was half right well thats .500 and thats pretty good in a Cubs fan eyes
post #19 of 26 (permalink) Old 01-12-2008, 10:00 AM
CKJ
Guest
Posts: n/a
Indeed, half is half better than none
post #20 of 26 (permalink) Old 01-12-2008, 10:12 AM
The o-rings on the water pump shafts are to seal the grease in the coupler.
post #21 of 26 (permalink) Old 01-13-2008, 09:28 AM Thread Starter
i changed the o -ring on waterpump shaft and no leak that is wierd
do you have to put hard grease in the waterpump shaft coupler
96supersport is offline
post #22 of 26 (permalink) Old 01-13-2008, 03:05 PM
I used anti-seize in mine but I am not a 100% sure if thats the proper way to go.
post #23 of 26 (permalink) Old 01-13-2008, 03:13 PM
Perhaps your shaft was wobbling and the o-rings helped stabilize it. I would have changed the timing cover seal while I had it apart.
A dab of axle grease should work on the shaft ends. You don't want the coupler and gears to eat each other up.
post #24 of 26 (permalink) Old 01-13-2008, 09:36 PM
CKJ
Guest
Posts: n/a
Axle grease or bearing grease would work best. Anything thats a hard grease that won't liquify and leak out. Hard grease will melt but its usually close to 450 degrees.
post #25 of 26 (permalink) Old 04-27-2011, 07:51 PM
oil leak/accelerating
whats wrong im leaking oil around my timing chain cover and im bogging down accelerating only if i try 2 go fast out the gate?????????
skibolo is offline
post #26 of 26 (permalink) Old 04-28-2011, 01:30 PM
How do you change the water pump drive seal without taking off the OPTI and everything else? Can it not be done? because it looks like the top of the OPTI is in the way by only an 1/8th of an inch to have it just slide off and on..
Poker Ace is offline
