How to plug Smog (AIR) ports in exhaust manifolds - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 19 (permalink) Old 07-30-2007, 04:53 PM Thread Starter
We are putting a '95 Camaro LT1 into a '86 Monte Carlo SS. While I was going to retain the engine in factory condition for the initial swap, I have found moving the A/C compressor from the passingers' side to the drivers's side of the engine with a Bowers Rod Shop relocation bracket kit to be a better alternative to notching the frame and fabbing a right engine mount. However, the Bowers bracket sits in the area of the factory AIR pump, so we have decided to delete the pump and lines. But, I am having no luck finding a set of threaded plugs to plug up the holes left in the manifolds. Does anyone have any experience in this area? Someone told me to look around bigger auto parts stores for a large metric oil drain plug for a ricer, but so far I haven't found a large enough plug......
Ditchwizard is offline
post #2 of 19 (permalink) Old 07-30-2007, 05:31 PM
LearJet's Avatar
I would plug them by installing headers that didn't have AIR/EGR fittings.
LearJet is offline
post #3 of 19 (permalink) Old 07-30-2007, 06:36 PM
mtperformance's Avatar
You can use headers for a regular gen 1 sbc on the LT1 just use the header gaskets that come with the headers or upgrade to copper or whatever you like . But if you want to use the manifolds I think they are pipe thread so maybe a trip to the hardwarestore is the answer.
mtperformance is offline
post #4 of 19 (permalink) Old 07-30-2007, 06:47 PM
CKJ
Guest
Posts: n/a
I wanna say its a 22mm plug.
post #5 of 19 (permalink) Old 07-31-2007, 03:11 PM
ProjektNitemare's Avatar
go to a menards or somewhere that has threaded rod, use a pitch gauge etc to get the right diameter and pitch or just bring in the little section of pipe with the nut on it to the store. then cut the length of rod flush with the hole and use some thead sealer or gasket sealer in the threads just to make sure its sealed.
95 Z28 w/95 Corvette LT1: .060" Over. 11.1:1 Compression. Arizona Speed & Marine Headers, and CAI. Flowmaster 3" Cat-Back Converter Delete. 160 Thermostat. Hypertech Programmer. Underdrive Pulleys. SPEC Stage II Clutch. B&M Short Throw Shifter. 315/35-17 Goodyears on Black Grand Sport Rims. UMI Shock Tower Brace, Adjustable LCA's and Panhard Bar. 4.10:1 Rear Gears w/Eaton Posi.
ProjektNitemare is offline
post #6 of 19 (permalink) Old 07-31-2007, 03:44 PM
Black93Z's Avatar
Send a message via AIM to Black93Z Send a message via MSN to Black93Z Send a message via Yahoo to Black93Z
or take the easier route go by napa and ask for a brake fitting thats 3/4 i think ask for however many you need and install em, i cant remember if its 3/4 or 7/8 but it is standard. or take in the fitting from the line that plugs into the manifold and ask for a fitting thats plugged, thats like the fitting from the manifold
Black 93 Z 6spd (M29): Rachel, gone but not forgotten
wish list: another f-body
97 c/k 1500, shift kit and 3k stall, OTVC wires, Magnaflow exhaust
Sex is like math: you add the bed, subtract the clothes, divide the legs and pray you dont multiply!
Black93Z is offline
post #7 of 19 (permalink) Old 07-31-2007, 07:15 PM
The size plug you want is M22X1.5
'81 Sport Coupe
406 Mouse/ Scat Crank/ 6" Rods/ Fully ported 2.02/1.6 Vortec heads/ Comp Cams XE284 K-Kit/ Canton Racing road-racing oil pan/ Ported Edelbrock Vortec RPM/Edelbrock 750CFM/ Hooker Sidepipes/ Full-Manual 4L80E/ 12-bolt 3.73 Posi/ C5 Z06 wheels/ C6 Z51 brakes
'93 Z28 5.7L LT1
Canton Racing Oil Pan/ PA Racing K-Member/ UMI SFC's/UMI STB/ 17x9.5/18x10.5 C5 Z06 wheels/ 275/40-17 & 285/35-18 Falken FK-452's/ MAC Mid-Lengths/ LPE CAI
hardline_42 is offline
post #8 of 19 (permalink) Old 07-31-2007, 08:00 PM Thread Starter
Hardline 42 got it. It is a M22X1.5 metric, and the easy fix is to go to your local auto parts store and get 2 replacement oil drain plugs for a '94 to '01 3/4 or 1 ton Dodge Truck with the Cummins Diesel engine.
Thanks everyone!
post #9 of 19 (permalink) Old 07-31-2007, 09:59 PM
Founder
Chris 96 WS6's Avatar
That's correct. They are metric M22
Chris 96 WS6 is offline
post #10 of 19 (permalink) Old 07-31-2007, 10:07 PM
CKJ
Guest
Posts: n/a
Thats the exact phrase I heard, M22, but thats been about 3 years ago when I heard that. Didn't want to speak too soon
post #11 of 19 (permalink) Old 08-01-2007, 12:45 AM
Black93Z's Avatar
the ones i got were standard and fit exactly, worked great, maybe its the earlier LT's that are standard, or maybe its kinda like other stuff metric and standard are so close together theyre basically the same
Black93Z is offline
post #12 of 19 (permalink) Old 08-09-2007, 01:17 AM
Send a message via AIM to Cyamaha2007
i saw a guy weld his closed
1995 Trans am with a trick flow intake elbow new jasper engine
Cyamaha2007 is offline
post #13 of 19 (permalink) Old 08-10-2007, 02:38 PM
With them capped and the egr tubes unplugged will you still pass the infamous smog test, for those of us in sniffer counties?
DAVE00
'95 T/A
383 Stroker
AFR190's, Lloyd Custom Cam and some goodies!!!!
Dave00 is offline
post #14 of 19 (permalink) Old 08-10-2007, 08:19 PM
i used a 5/8 flare cap on my pacesetters cause i wanted to keep the egr fitting. just go to a lowes or home depot in their plumbing section. thats where i found them.
chevy dude is offline
post #15 of 19 (permalink) Old 08-13-2007, 11:12 PM
LearJet's Avatar
LearJet is offline
