LS1 to 700R4 - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 6 (permalink) Old 01-24-2011, 07:04 PM Thread Starter
Send a message via Skype™ to elwaupo
LS1 to 700R4
I have a 69 Camaro with a 350 small block and I'm thinking of converting to an LS1 or LS2. Would an LS motor bolt up to a 700R4?
elwaupo is offline
post #2 of 6 (permalink) Old 01-25-2011, 08:16 AM
Runs with scissors
Greed4Speed's Avatar
It should. People run th350 and 400's with them.
Just two slow 4 doors.
Greed4Speed is offline
post #3 of 6 (permalink) Old 01-25-2011, 09:41 AM
95Z
Admin
You will need some sort of adapter as the bell housing patterns are different on a gen 1 than a gen 3 and you'll also need a proper flexplate. You'll also need a tv and kickdown cable, but that shouldn't be too hard to do. I've never looked into the conversion, so I can't offer you any part #s or products.
Yep its slow.
95Z is offline
post #4 of 6 (permalink) Old 01-28-2011, 08:06 PM
Talking
you will need a specific flexplate for it. there will one bolt that will not line up (not sure which one). then go to bowtieoverdrives.com and look at there tv cable bracket kit that works for this swap. then get a tune for a manual which will take the tranny out of the equasion.
YOU MUST ALWAYS PUSH THE LIMITS...IF YOU NEVER FAIL YOU WILL NEVER SUCCEED...NO FEAR!
one92rs is offline
post #5 of 6 (permalink) Old 02-23-2011, 08:56 PM Thread Starter
Unhappy
Sounds like it would be easier to use the transmission that was made for that application, being that everything is computerized.
elwaupo is offline
post #6 of 6 (permalink) Old 05-19-2011, 04:15 AM
greenjeens's Avatar
(P/N 712500A) | Advance Adapters LS adapters for several different types of transmissions, and have the computer tuned to think it has a manual trans. Should be a simple check box, x=4L60E enabled, and no X=4L60E disabled, in the PCM. Software to tune the LS/vortec motors I think is 799.00.
greenjeens is offline
