spark plugs - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 12 (permalink) Old 07-20-2009, 07:21 AM Thread Starter
spark plugs
hi guys i finaly decided to change my sparg plugs and wires i got a 2002 trans am ls1 whitch plug is better and wy? TR55 - NGK V-Power Spark Plugs, TR55GP - NGK G-Power Spark Plugs, or the TR55IX - NGK Iridium IX Spark Plugs and also what would be a good wire to go with the plugs i was considering useing the Taylor #895-84244 THUNDERVOLT 8.2 CUSTOM 8 CYL RED is this a good choice foe wires? thanks guys
spydog is offline
post #2 of 12 (permalink) Old 07-20-2009, 07:55 AM
ive run both tr55ix and tr55 plats with no complaints, and id pass on the taylors. stick with msd for the wires.
94 formy a4, solomons tune for stuff ive done ! http://www.youtube.com/watch?v=2auIR-B0tvY
Originally Posted by Hughges View Post
2+2 does not= chair.
laux06 is offline
post #3 of 12 (permalink) Old 07-20-2009, 03:59 PM Thread Starter
whar would i get the best deal on the tr55 plugs and on msd wires and also should i buy the SLP special spark plug socket for LS1 its supose to be easer to change spark plugs with is it worth the $30
spydog is offline
post #4 of 12 (permalink) Old 07-24-2009, 07:28 PM
Runs with scissors
Greed4Speed's Avatar
Just get plugs at a part store. I prefer copper. Yes, you have to change them more often, but copper is a better conductor.
I have ran Taylor wires for years and have had no problems with them. I've heard good and bad about both Taylor and MSD wires though. Its all in who you talk to, just like some people like Fords for some odd reason. Get which ever you get the best deal on. 8mm, 8.2mm, 8.8mm doesn't matter. Its just the thickness of the insulation. Our wires are so short even the stock wires do fine.
Greed4Speed is offline
post #5 of 12 (permalink) Old 07-24-2009, 07:38 PM
Yo!
R3DLT1's Avatar
yeah just buy the spark plugs at your local part store. I bought mine at Napa i think less than 20 dollars.
R3DLT1 is offline
post #6 of 12 (permalink) Old 07-24-2009, 11:13 PM
03slowZ06's Avatar
What he said. Plain jane copper. It wears faster but it conducts better and the heat transfer out of the copper is a ton better then other plugs.
u can do it
03slowZ06 is offline
post #7 of 12 (permalink) Old 07-28-2009, 10:32 PM
will speak even though im a lt1 man myself.... i had a 99 and the best spark plug that didnt cause any trouble was ac delco... what ever u do dont get bosch they suck they all went out and burnted my plugs and some coil packs
but just my 2 cents
silverbird95 is offline
post #8 of 12 (permalink) Old 07-29-2009, 07:11 AM Thread Starter
i have bosch platnum 2s in my 98 pontiac bonnaville SSE and have never had a problem with them this is my 2nd set in that car but i think i am going to go with the tr55 for my trans-am i am going to start replacing them next month when i get back home
spydog is offline
post #9 of 12 (permalink) Old 07-29-2009, 09:32 AM
94greenbandit's Avatar
I tried the Boschs in my camaro as well and they would just make my car stutter. Switched to the Iridum NGKs and no trouble now
94greenbandit is offline
post #10 of 12 (permalink) Old 07-29-2009, 07:31 PM
Runs with scissors
I ran the regular Bosch in my Camaro when it was bolt on and cammed. Never had a bit of trouble from them. With my current set up, I'm running NGK TR6's.
post #11 of 12 (permalink) Old 08-01-2009, 07:33 AM
SOMSS's Avatar
Send a message via AIM to SOMSS
Delco Irridiums are the OEM spec plugs, Coppers are fine if you like changing plugs! Get whatever fits your pocket. As for plug wires MSD is a sure bet, Taylors aren't bad either.
2001 Camaro SS- 6spd T-Tops, Neutral Leather, 1SD options, ASR.
MODS: Dart Pro heads, custom cam. BMR - SFC,TA,STB. UMI- LCA, Adj. PHR. K&N FIPK, SLP- MAS, Smooth Belows, Koni SA's, Ground Control Coil-Overs, Pro 5.0 shifter, Kooks LT's. Corsa Exhaust,T/A Girdle, C5 ZO6 brakes, Goodridge SS brake lines. MSD 8.5mm Wires, Racetronix fuel pump. Ported TB, Forged bottom end, balanced and blueprinted.
SOMSS is offline
post #12 of 12 (permalink) Old 08-01-2009, 04:23 PM
Runs with scissors
I laugh when people post this. GM also installed Denso. Thats what mine and many others came with.
One thing to watch for when looking at platinum plugs is the platinum disk they attach to the ground. The disks have been known to fall or burn off increasing the gap. I pulled my stockers @ 28k miles to put on some Mac headers and at least half of them were missing the platinum disk. I would not use any plug that has the disk design.
Coppers don't go bad that fast either. Mine have been in for 15k miles (a year) and are still fine. I just ran a new personal best ET a couple weeks ago, but I will be pulling a few to check them soon just out of normal maintenance. I would do the same with any plug, just like I wouldn't leave Dexcool in as long as they claim it will last.
