Faster Car??? - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 9 (permalink) Old 01-03-2013, 09:02 AM Thread Starter
Linson's Avatar
Faster Car???
technical opinions needed. which car would be faster?
67 Firebird
3250 lbs
LS376/525: 525 hp / 490 tq
4 spd auto
or
67 Chevelle
3600 lbs
ZZ502: 500 hp / 550 tq
3 spd auto
Linson is offline
post #2 of 9 (permalink) Old 01-03-2013, 01:04 PM
Runs with scissors
Greed4Speed's Avatar
What gears, tires, rear, converter etc.? I'm guessing the hp is the rating of the crate engine, or are you talking actual numbers at the wheels?
Just two slow 4 doors.
Greed4Speed is offline
post #3 of 9 (permalink) Old 01-03-2013, 01:42 PM Thread Starter
Linson's Avatar
Generally lets just say same-same-same for the sake of arguement. and yeah, the numbers posted are the advertised flywheel numbers.
Linson is offline
post #4 of 9 (permalink) Old 01-03-2013, 04:20 PM
I know nothing about these two cars, but a shot in the dark tells me the firebird. Better power to weight ratio usually wins races. But that's just a blind guess. I'm curious to see if I'm right
Sent from my Galaxy Nexus using AutoGuide.Com Free App
1994 Camaro Z28 19x,xxx miles New LT1 and built 4L60E - K&N CAI, Elbow, Air Foil, kooks LT headers, True Duals w/ Dynomax Bullets dumped, 160° stat & fans on early, EGR & AIR delete, EWP, 255FP, ProTrorque 3200 stall, Pcm for Less tune, ET Streets 12.886 @105.12 1.779 60'
Xzauhst is offline
post #5 of 9 (permalink) Old 01-03-2013, 07:57 PM
bym
bym's Avatar
haaa, take it the easiest way out... race them...
traction, gear ratios, and true power would be measured at the wheels not advertised....
with this numbers i would go with the Firebird... but you might have amazing numbers on the engine and weight but without putting them to the ground is like not having them at all...
Camaro from Guatemala
12.22@112mph on nittos 555rīs
bym is offline
post #6 of 9 (permalink) Old 01-03-2013, 09:22 PM
Runs with scissors
Same gear ratio say a 3.08, I'd guess the 502 with more torque. But if they're both rolling a steep gear the bird for the higher HP. Set up means everything. You need specifics to make anything beyond a wild guess.
post #7 of 9 (permalink) Old 01-05-2013, 01:02 PM
DUDBIRD113's Avatar
Depends on how well each car hooks. U can have 500hp and try to race and just be a burnout show
94 TA GT Stock 350 lt1, cam, exhaust
DUDBIRD113 is offline
post #8 of 9 (permalink) Old 01-07-2013, 07:30 PM Thread Starter
Linson's Avatar
set-up wise, in a general sense, i just meant which would tend to be the faster car. i'm thinking 350-ish gears on the Firebirdd and 325-ish gears on the Chevelle.
i have the Firebird, a rolling chasis with new paint/body. i dont own a Chevelle but intend to get a '67 Chevelle project as soon as the right deal comes along.
my initial inclination would be to believe the Firebird would be quicker - but was not sure if all those cubes and torque would be enough to overcome the Firebird's advantages.
does that better frame the question?
Linson is offline
post #9 of 9 (permalink) Old 01-07-2013, 08:27 PM
bym
bym's Avatar
id stand closer to the lighter car.... plus look into prices on parts, that should give you a great view on what you can do
bym is offline
