air bag question - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 8 (permalink) Old 03-23-2010, 06:40 PM Thread Starter
bruiserman's Avatar
air bag question
I was reading that if you remove the airbag and try to put the same bag back in, the airbag dash light will still light up meaning the system is disabled. Is this true? I can't remember where I read that. I need to replace the signal turn off switch because when I turn left the blinker doesn't shut off. It's annoying but I'd rather leave it if the original airbag can't be replaced. I'm not going to buy a new airbag if that is what it takes.
I eventually want to get rid of the airbag and get a different steering wheel anyway, so if I can't reuse the original airbag I just won't do the repair till I am ready to replace the steering wheel.
1995 Trans Am convertible, 3.23 gearing, CAI, BBK shortie headers, Cam, A/C delete, drilled/slotted rotors
2006 Kawasaki ZX14, flies removed, exhaust, powercommander, extended 4"
bruiserman is offline
post #2 of 8 (permalink) Old 03-23-2010, 06:56 PM
YeaIDriveAWagon's Avatar
I know airbag systems can get really touchy. Not 100% positive on if it will permanently disable it or not though. I would definitely suggest that unless you can find a credited source saying that it wont mess the airbag system up that you wait until you are ready to replace the steering wheel.
1995 Caprice Classic Wagon, LT1, K&N FIPK Gen II CAI, Custom True Dual Catback Straight Pipes, Throttle Body Bypass, 160*F Thermostat, A/C Bypass Pulley, 9C1 Air Valence, Home Plate Delete, Manual Fan Switch, Lowered Suspension.
Plus It Seats 9!!!
1986 Pontiac 6000 LE w/ the 2.5L Iron Duke! It's got all 98 horses, baby!!!
And a 1992 Honda Civic DX
SOLD
YeaIDriveAWagon is offline
post #3 of 8 (permalink) Old 03-23-2010, 07:43 PM
No from what I understand that is not true at all. People have to remove the driver side air bag for things like that all the time.
There is a fuse in the fuse box labeled SIR or SRS. You need to pull that fuse and the air bag should no longer have power.
If you don't mind re-setting your stations I would remove the battery just to be safe.
The air bag and electrical system can hold a charge so I would wait 15-30 minutes.
Unplug the yellow wire coming out of the steering column and you should be safe to remove the air bag with no issues.
Its such a dangerous device, trying not to have your head in front while removing it is probably not a bad idea
autotrix is offline
post #4 of 8 (permalink) Old 03-23-2010, 07:57 PM
10 Second Opti Club
sweetbmxrider's Avatar
just disconnect the battery for half an hour. it will be fine i've done it plenty of times. now i have a grant wheel.
sweetbmxrider is offline
post #5 of 8 (permalink) Old 03-23-2010, 07:59 PM
Spartan7's Avatar
No. I've removed the air bag a few times. Just to what autotrix said above to disable the system, and you should be fine. Make sure when you remove the air bag that you place it right-side-up (that is, the rubber part of the steering wheel up) and away from you.
1997 Pontiac Trans Am WS6 clone | Build Thread | - just needs paint!
2001 Chevy Silverado 2500HD (the DD)
Spartan7 is offline
post #6 of 8 (permalink) Old 03-23-2010, 08:47 PM Thread Starter
bruiserman's Avatar
Sounds good. Will try it soon. Those airbags are crazy. I work for the fire department and we have to watch those things all the time when we are messing with cars. We usually cut the battery wires or disconnect them but we don't have the luxury of waiting 20 min. I definitely will let it sit till power is drained. Just glad I can fix that signal.
post #7 of 8 (permalink) Old 03-23-2010, 09:36 PM
autotrix is one of those credible sources I was talking about haha
I'd say go for it then and to wait the full 30 minutes just to be safe.
Plus It Seats 9!!!
SOLD
post #8 of 8 (permalink) Old 03-24-2010, 06:21 PM
bym
bym's Avatar
disconect the battery, let it sit for half an hour or so, then disconect the air bag system and then take the air bag out, you dont want it to explode in your face.
if you follow up this steps, you will not get the air bag light on unles you missed something in the way,,,,
good luck
Camaro from Guatemala
12.22@112mph on nittos 555rīs
bym is offline
