Question vats security light on - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 1 (permalink) Old 04-21-2017, 08:04 AM Thread Starter
97z28convt's Avatar
So ive done some reading and will continue to do more.. but figured ide throw up a post to see if anyone familiar with this system wants to chime in ..
My security light has been on in my 2000 z28 since i baught it 2 years ago.. runs and drives fine. it broke in the on position. so i got lucky i guess.
but figured ide get around to fixing it finally . OHMed out the key, its got 886 resistance. Key pellet "4" stuck the key in the ignition turned it to on while probing the vats wires.. "0" ie it needs a cylinder or wires or whatever. got a 900 ohm resister wired it where the vats wires plug in. orange coated wires that go to the ignition are completely unplugged. Carstill starts fine , but no change, security light stays on.
Do i need to reset the battery or something? or will the resistor trick just not work? does that mean i need a new BCM, can i just throw any bcm into it, ive got extras from cars ive parted out.
Tips/ Help apprecaited.
97 z28 convt, 60k mi. TF heads, 1.6 rr, rods, lifters, comp cam, msd cap rotor coil, full exhaust, Cai, Pcm for less tune , 150 nitrous, no air or egr, tb bypass 3200 stall. 410s. 12.5 spinning on slicks.ugh..
1971 chevelle w ls1 & dakota digital dash, true duals w xpipe, 4whl disc,342s
05 corolla xrs.. one of 5000 made. 00z28convt.
98z28 hard top.. project waiting
89 mustang gt... i know i know..
sold-02 z28 m6, 68 continental sedan, 95TA, 86iroc, 88z28
97z28convt is offline
