Question throttle adjustment/ cruise controll help - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 2 (permalink) Old 04-10-2017, 08:53 AM Thread Starter
97z28convt's Avatar
so.. I took my throttle body off to do some work and upon reinstalling it my car is now having an idle issue.. its not returning to base idle.. took the adjusters off both cables to attempt to fix it that way.. and even removed the cables from the cruise controll module. I have been able to confirm the problem lies with the cruise controll module that sits directly behind the battery.. Its just not returning are far back as it should and that is causing the throtttle to remain open.. I can push it back by hand, but then as soon as i hit the gas itll sit partway open again. is there any kind of reset procedure for this? or should i just replacece it ? pretty sure i have an extra one laying around.
thanks
97 z28 convt, 60k mi. TF heads, 1.6 rr, rods, lifters, comp cam, msd cap rotor coil, full exhaust, Cai, Pcm for less tune , 150 nitrous, no air or egr, tb bypass 3200 stall. 410s. 12.5 spinning on slicks.ugh..
1971 chevelle w ls1 & dakota digital dash, true duals w xpipe, 4whl disc,342s
05 corolla xrs.. one of 5000 made. 00z28convt.
98z28 hard top.. project waiting
89 mustang gt... i know i know..
sold-02 z28 m6, 68 continental sedan, 95TA, 86iroc, 88z28
97z28convt is offline
post #2 of 2 (permalink) Old 04-21-2017, 07:58 AM Thread Starter
97z28convt's Avatar
well im a moron.. i swapped my 98 and 00 throttle bodies over winter trying to diagnose a different problem and didnt realize i forgot to swap them back... the 00 throttle body has a bigger "blade" that the cable runs on.. hence the 98 cable is too short.. and cannot be adjusted long enough.. swapped um back, adjusted the cables and im good to go..
