Urgent im stumped on this guys rear drivers caliper is locked up?? - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
Go Back   LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums > Chassis & Powertrain Tech > Chassis | Suspension | Braking | Wheels & Tires
Old 11-13-2012, 04:27 PM   #1
94Ztwentylate user's tech expertise is unknown at this point
Default im stumped on this guys rear drivers caliper is locked up??
im stumped on this guys.rear drivers caliper is locked up??ive replaced the caliper, brake line ive greased and cleaned the slide pins, and checked for smashed hard lines..ive even blown out the lines on my 94 6 speed camaro lt1.i dont know if it matters but i just swapped from auto to 6 speed on the car. but the drivers rear locks up after about 3 or 4 miles and makes the car almost impossible to drive and then brake starts smoking..so somebody please help me out here the only thing i havnt replaced is the prop valve but i was under the impression both rears would be effected..help please!!
SLP lm 1,shift kit,volant ram air,MSD 6AL...UMI panhard rod and LCA's, SLP subframes and strut tower brace,eibach pro drop springs,drilled & slotted rotors, 02 Z06 wheels(gun metal),Brand new interior out of a 2000 SS...needs a dyno..
full bolt on and cam and recent 6 speed swap for A4.
94Ztwentylate is offline
Old 11-14-2012, 04:54 AM   #2
Transamman25's Avatar
Transamman25 Apprentice Level Tech III
Start out by flushing the brake fluid in the rears, have a friend help you by bleeding the lines until you have fresh clean fluid. I would disconnect the line where it feeds both rear brake lines and flush the fluid out looking for any sedimate. You will probably go through 2 quarts of brake fluid to get the lines truely clean.
The correct bleed is always working towards the master cylinder so the order is RR,LR,RF,LF. Once you are sure there is no air in the lines and no issues in your brake fluid test drive the car, and verify the condition still exists or if that cleared the problem.
Transamman25 is offline
Old 11-14-2012, 09:04 AM   #3
95 Firehawk's Avatar
I would double check that you got the right pads. I had a similar problem with my girlfriend's blazer earlier this year. It turned out the part number they gave me was xxx792, when they should have given me xxx729. The wrong ones fit in the caliper (not as easily as I would have thought) and could be squeezed over the rotor with not too much effort. The brakes eventually would heat up and smell badly, and within my 10 mile drive from her work back to my house, I had boiled the brake fluid and barely had brakes. When I finally got the correct ones, they were 1/8" thinner than the wrong ones, even after basically driving around with the brakes on for a day.
95 Firehawk is offline
Old 11-14-2012, 10:40 AM   #4
trans am man i already did that literally sunday night..and the pads are correct i checked those to..i think im just gonna replace the prop valve unless anyone has got a better idea?i already have steel braided lines to put on so il probably just redo everything...
Old 11-14-2012, 01:17 PM   #5
Is the abs kicking in at all ?
Old 11-14-2012, 02:07 PM   #6
the abs isnt plugged in.. i havnt had it plugged in in the 2 and half years ive had the car
Old 11-14-2012, 03:35 PM   #7
When you say you replaced the caliper, did you put a new, rebuilt or used caliper on. If you installed rebuilt or used your caliper might be the problem.
If calipers aren't the problem, have you checked for a bad master cylinder not releasing the back brakes.
Maybe a proportioning valve that has gone bad, not letting brake fluid leave the rear caliper.
Old 11-14-2012, 03:42 PM   #8
Runs with scissors
Greed4Speed's Avatar
Greed4Speed Tradesman Level Tech I
Had to see what was going on in a thread that shows up on the main page titled as "I'm stumped on this guys rear"
Just two slow 4 doors.
Greed4Speed is offline
Old 11-14-2012, 03:43 PM   #9
It was a used caliper.what makes you say that though just for future reference?
Old 11-14-2012, 04:00 PM   #10
You never know if a used brake caliper has a stuck piston or not. That's why I stay away from used brake parts. Rebuilt caliper has a chance of being bad right out of the box, though it's a small chance compared to used brake parts.
Old 11-14-2012, 04:11 PM   #11
The proportioning valve would only compensate front-rear bias and you would have the same issue on both sides. I would thoroughly check the parking brake system to rule that out.
Old 11-14-2012, 04:22 PM   #12
Keesling user's tech expertise is unknown at this point
^ he is right about the prop valve, I would say it is your caliper man not a whole lot else it could be.
I would take it off or pump it with it off to see if it moves in and press it back in with a c clamp a few times.
you bled it right?
Keesling is offline
Old 11-14-2012, 04:29 PM   #13
Yes i bled them alot lol..and thats what i thought anout prop valve..but note i will replace the caliper witha brand new one..and i guess i will update this when i do that thanks alot yall!
Old 11-14-2012, 09:35 PM   #14
omarcamaro user's tech expertise is unknown at this point
check your brake cables they tend to stick when not used a lot the car was auto and you made it a six speed had that happen to me before
67 rs
70 rs
95 z28
omarcamaro is offline
Old 11-19-2012, 06:04 PM   #15
okay i replaced the caliper with no effect and the wheels locked up again.but we opened the bleeder on the abs module and they released so is it the module or the vss..but i was thinking could the vss sensor sense it needs to be replaced and doesnt read correctly..could it effect the the brakes??
