Question fuel pump wont run..help please!!!! - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
Go Back   LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums > Platform Specific Tech > B-body Impala SS/Caprice
Closed Thread
Old 11-20-2009, 11:16 AM   #1
My Facebook
96impalaustin user's tech expertise is unknown at this point
Default fuel pump wont run..help please!!!!
i went on the impala forum and didnt find anything about this problem i have. short story i had 2 codes p0200 and p0300, i was driving and the car pretty much stalled rpms went to zero and i let off the gas as soon as it did it and it came back to life.. went inside the shop came back out and the car would stumble really bad and shake so i finally got it to run good enought to get it home then took a nap cam back out the car did the same again.. when i turn the key on and off you cant hear the pump and you cant see it come out the fuel line.. i dropped the tank of course my friend got there and told me how to bypass the relay and we got the pump to run.. i replace the pump relay and it didnt do anything still cant figure out the problem?
1996 Chevrolet Impala ss, 2 1/4" true dual Flow master cat-back, 26lbs injectors, 160 stat, rebuilt trans with shift kit, DDM tuning H.I.d kit
96impalaustin is offline
Old 11-20-2009, 01:04 PM   #2
mrcadillac's Avatar
My Facebook
mrcadillac Apprentice Level Tech III
Isn't there also a fuse for the fuel pump?
~Cory Magner "My name is Cory, and I'm an addict."
95 DCM Buick RMS 14.21 at 91.79 "Jesus" Motor Swap at 85k
95 DCM Buick RMS 13.52 at 99.33 Buffmans Car Cracked Piston at 180k
RAISS, Tri-Y's, Pypes X pipe, Spintech Prostreets, 3000 Edge, 3.73's, Eaton Posi, and the rest of the Bolt-ons.
Coming soon! 845 cammed 96 9C1 engine.
And 7 other LT1 B-body's... Is there Rehab for this Sh*t?
mrcadillac is offline
Old 11-20-2009, 02:27 PM   #3
My Facebook
i dont know? i dont think so but i do know theres 2 fuses for the injectors
Old 11-20-2009, 10:58 PM   #4
retirednak's Avatar
retirednak user's tech expertise is unknown at this point
What kind of shape was the wiring in on top of the tank? The wires tend to short out or melt. Did you check fuel pressure?
'96 Caprice
37K,LT1 B4U
Home Plate/First Base Delete
K&N FIPK
SStreetlights
Sequential turn signals
Custom tune by pcmforless.
retirednak is offline
Old 11-21-2009, 07:27 AM   #5
My Facebook
i dont think its the wires because i can send 12 v to the pump by the fuse box and the pump will run..
does if have to be under pressure just to run with the key
Old 11-21-2009, 10:27 AM   #6
retirednak's Avatar
You may have a pump that runs but isn't putting out enough pressure to make the car run. You can pick up a pressure gauge and adapters for $20 at the local parts store.
code P0200 is injector control circuit
code P0300 is engine misfire Detected
'96 Caprice
37K,LT1 B4U
K&N FIPK
SStreetlights
Old 11-21-2009, 10:29 AM   #7
My Facebook
i did about a month ago and i got 38 psi, the thing is i turn the key and it wont run but i can but a 12 volts to a fuel pump wire in the engine compartment and make it run
Old 11-21-2009, 10:41 AM   #8
retirednak's Avatar
Do you have a FSM?
'96 Caprice
37K,LT1 B4U
K&N FIPK
SStreetlights
Old 11-21-2009, 12:53 PM   #9
My Facebook
Do you have a FSM?
whats a FSM?
Old 11-21-2009, 01:36 PM   #10
retirednak's Avatar
factory service manual
'96 Caprice
37K,LT1 B4U
K&N FIPK
SStreetlights
Old 11-21-2009, 01:48 PM   #11
My Facebook
the one that came with the car yes and i bought one from autozone
Old 11-21-2009, 02:00 PM   #12
retirednak's Avatar
I'm talking about the GM service manual,there is 2 books both red colored.
If you do have the correct manuals they will run down step by step how to trouble shoot each code your car has thrown. I wish the impalass forum was up and running,you might be able to find somebody able to help you better then I can. I have my manuals but it would take way too long to type out.
'96 Caprice
37K,LT1 B4U
K&N FIPK
SStreetlights
Old 11-21-2009, 02:23 PM   #13
My Facebook
where can you get one and how much?
Old 11-21-2009, 02:50 PM   #14
retirednak's Avatar
I bought mine on ebay.com and I paid something like $45 or $50. Most are used but sometimes you might find a brand new set. Mine was used and had old greasy finger prints on it,but for the most part pretty good shape. The FSM are heads above the books you buy at the parts stores. They have easy step by step instructions a kid could follow.
'96 Caprice
37K,LT1 B4U
K&N FIPK
SStreetlights
Old 11-21-2009, 03:17 PM   #15
retirednak's Avatar
The other site is finally up and running. I borrowed this from the other site. To test Rent (Free when you return it) a Fuel pressure gauge from Autozone or Advanced auto parts. Then connect it as previously descibed to the Schrader valve A helper turning the key forward (Not starting the car) to do the test would be a plus here.
Fuel pressure testing
1. Remove cap on schrader valve, Connect the fuel pressure gauge to the schrader valve.
2. Ignition OFF For 10 Secs - AC turned OFF
3. Ignition key ON, Fuel pump will run for approx 2 secs.
(It may be nessasary to cycle the Igniton key OFF and ON more than once to obtain max pressure)
4. Note max pressure on the gauge with the fuel pump running.
Pressure should be between 41-47 PSI
'96 Caprice
37K,LT1 B4U
K&N FIPK
SStreetlights
Closed Thread
