01-23-2013, 12:24 AM
Stall converter
Thinking bout buying a 3600 edge street convert for my 94 camaro for 300 bucks my car is only a bolt on car right now and I plan on doing a h/c install later my question is is that to much stall for a bolt on car or will it be good
01-23-2013, 06:13 AM
I've ran the Yank SS 3600 for 8 years with just bolt-ons.
1989 jaguar xjs, '93 z/28 eng.& trans. asp pullies,csi,1.7 scorpions,26918 springs, transgo, yank ss3600, homemade shorties,dr. gas x, alvins tune 12.82@104 1.74 60' 3900#
01-23-2013, 07:31 AM
Yo!
Re: Stall converter
I've seen plenty of ppl run any where from 3000 to 3800 on a bolt on car. I think is safe to say ur good. I personally would have no concern running a 3600 on a bolt on car. Especially if u plan a h/c/i in the near future
01-23-2013, 09:04 AM
Alright that sounds good r3dlt1 thx for the advice
01-23-2013, 05:23 PM
3600 is alot of stall for a bolt on car, especially if it's full weight. BTW, Edge converters are junk. I've seen way too many come apart and not work worth a crap if they work at all. They're great for destroying transmissions.
Frank
01-23-2013, 11:28 PM
Alright so does any one else have any input on edge converters good or bad any input will be greatly appreciated thank u
01-23-2013, 11:36 PM
I'd also like to add that I work closely with a local converter shop that does all my cut and cleans. I've seen inside most of everyones converters. There's a reason Edge converters are so cheap...Because they're a crappy converter.
Frank
01-24-2013, 12:53 AM
If your gunna do it do it right the first time thats my .02
Bone Stock 01 SS m6
01-24-2013, 08:34 AM
I've had two with great results, customer service is great and I don't consider $600 cheap for a converter. Been racing and street driving mine for four years now. I know lot's of people that run them and no problems.
01-24-2013, 12:44 PM
4000 stall with 3.73 = alot of fun.
 slp cai..p&ptb..ls6intake...pacesetter lts..tsp true duals..4000revmax stall..motive3.73s..UMI strut..lcas..ta..
ph rod..bilsteins/springs..poly mm..frost tune.
Tick performance SNS stage 3 234/244 111+3...performance built transmission
