Transmission Jack - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
Go Back   LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums > Chassis & Powertrain Tech > Automatic Transmissions | Torque Converters
Old 01-17-2013, 02:33 PM   #1
Default Transmission Jack
Has anyone ever used one of these: Transmission Jack - 450 Lb. Capacity
I just ordered one and was wondering how well it works.
Best 1/4 so far 11.20 @ 118.42 1.53 60ft 3700lbs 1900 DA.
Mystery Bird is offline
Old 01-17-2013, 05:00 PM   #2
I have used the taller version of that in conjunction with a lift, makes it easy to really yank on the trans and feel safe it won't come fall on your face.
Old 01-18-2013, 12:32 AM   #3
Dynamic396's Avatar
It will work fine for occasional use, but for more frequent use, I'd upgrade...
hey, just bring that thing over here and you can use my lift and jack...! Just buy the beer!
Dynamic396 is offline
Old 01-18-2013, 07:53 AM   #4
We'd end up fighting.
Old 01-18-2013, 05:11 PM   #5
Dynamic396's Avatar
OK, then...
Old 01-18-2013, 07:36 PM   #6
95 Firehawk's Avatar
Cyberbullying is an epidemic!
Looks better than my crappy tranny jack. I have to carefully balance my T56 within a few inches and it still wants to fall off. I'm thinking of fabbing up a custom craddle to hold it better.
95 Firehawk is offline
Old 01-19-2013, 08:26 AM   #7
Originally Posted by Dynamic396 View Post
OK, then...
I'm just messin, you know I love ya brother. If I came over to your garage I'd never leave.
This should do better than man handling it up on a floor jack with an adapter and with going to a 4l80e that option is just out of the question.
Old 01-19-2013, 08:46 AM   #8
Drop engine out and do it the easy way.
Old 01-19-2013, 12:51 PM   #9
Dynamic396's Avatar
I know, man... I got ya...! Just messin' back - "Sling Blade" style...
We could cause some serious mayhem if you lived over here!
Old 01-19-2013, 03:44 PM   #10
Or if you were over here.
Old 02-09-2013, 07:16 PM   #11
kwacasey user's tech expertise is unknown at this point
I might be a little late in responding but i did buy and use this jack from HF. Worked well. In my case i just needed to get the trans off the guide pins without dropping it directly onto the ground. When re-installing i wrestled the trans back onto the jack under the car and was able to put everything back together by myself.
1993 Camaro Z28 A4 (4L60 non-"E")
K&N CAI, BBK TB, Superior Perf. Shift reprogramming kit, Corvette Servo, NGK TR55IX plugs, Taylor Cable Thunder Volt 8.2mm wires.
-You know that your paint is in bad shape if you familily has nick named your car "CHIP"
kwacasey is offline
