They work great. I use them a lot on snow plow trucks. Snow plows are murder on automatic transmissions due to low airflow across the cooler (plow in the way). I like the ones with a thermostatic switch to control the fan.
I always add an external cooler in addition to the factory cooler in the radiator. I don't recommend replacing the factory cooler with an external cooler. It should be in addition to the factory cooler. The flow should be: out from the transmission into the radiator, then out of the radiator and into the aux. cooler, and then out of the aux. cooler and back to the transmission. (FWIW, the lower line on a 4L60E is the "out") When you're done, just make sure you have good flow through the whole system. the return from the cooler is the lube (and cooling) for your gear train.
