Torque Converter - Page 2 - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #16 of 16 (permalink) Old 12-25-2012, 11:20 AM
Dynamic396's Avatar
He doesn't need to change the stall speed, he just needs a converter that's not out of balance.
You keep referring to a "stall" converter. What's your definition of a "stall" converter?
Dynamic396 is offline
