700r4 need help - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 5 (permalink) Old 11-11-2012, 08:42 PM Thread Starter
Angry 700r4 need help
Alright well I own a 93firebird with an automatic 700r trans and I'm having a problem which is if I mash the gas to hard it feels like my tranny wants to break throughy car it keeps knocking and rising which even hurts me I already replaced the tranny mount which was one of the probles before but now it still doing the same but not as bad p.s yes mount is still good
Edgar661 is offline
post #2 of 5 (permalink) Old 11-12-2012, 12:11 PM
cahall's Avatar
Did you put a cheap mount on it? This still sounds like a broken or weak mount...Or the bolt or nut being missing that holds the mount to the crossmember.
Frank
cahall is offline
post #3 of 5 (permalink) Old 11-13-2012, 08:36 PM Thread Starter
No actually all of that is in good condition still Do u have any other suggestions as to what it can be
Edgar661 is offline
post #4 of 5 (permalink) Old 11-13-2012, 08:59 PM
2cat95TA's Avatar
That sounds exactly like a broken tranny mount, maybe check the torque arm mount?
95 Trans Am A4, factory 3.23s, Ram air, Phab catback, shift kit, BMR front and rear sway bars, Lakewood LCA's, UMI subframe connectors, Random Tech TA, Founder's Performance strut tower brace and PHR
99 Saturn sl2 M5, 92 header-daily driver
2cat95TA is offline
post #5 of 5 (permalink) Old 11-13-2012, 11:04 PM Thread Starter
Hm thanks I will do that probably use my schools lift and see what's up thanks for the suggestion
Edgar661 is offline
