Help ASAP!!! Cars speedometer doesnot work and transmission has 1-3shift only - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 21 (permalink) Old 10-27-2009, 10:25 AM Thread Starter
zsu
zsu's Avatar
Question Help ASAP!!! Cars speedometer doesnot work and transmission has 1-3shift only
HELP ASAP!!!!!!!
My cars speedometer doesnot work, and 1-3 gear shift only!
It happened after Car entered a big cavity at road..
Any ideas???
What should I do?
I have checked under my car there is no unplugged wire looking there..
zsu is offline
post #2 of 21 (permalink) Old 10-27-2009, 10:26 AM
mrbadlt1's Avatar
Send a message via AIM to mrbadlt1 Send a message via MSN to mrbadlt1
govenor gear in the tail shaft maybe broke, what year?
Tyler's 1993 Chevrolet Camaro Z28
6LE Longtubes / LPM Heads / LE Cam / Vigilante 3200 / Shinholster 4L60 / GM 3.73's
mrbadlt1 is offline
post #3 of 21 (permalink) Old 10-27-2009, 10:35 AM Thread Starter
zsu
zsu's Avatar
sorry for not writing year..
1995 stock transa am, auto trans...
Broken?
I donot know that part.. :/
Any link for picture of that part?
zsu is offline
post #4 of 21 (permalink) Old 10-27-2009, 10:42 AM
mrbadlt1's Avatar
http://www.transmissionhead.com/index.9.jpg
this is it on the 4l60, not sure if its the same on the 4l60, its a plastic ggear in the tailshaft that controles the speedo and shifting of the trans, now that i think of it the 4l60e may not even have it, i would talk to 95z about this he knows the 4l60e's good.
mrbadlt1 is offline
post #5 of 21 (permalink) Old 10-27-2009, 10:47 AM Thread Starter
zsu
zsu's Avatar
Damn :/ I hope its a simple problem?? cuz Iam tired of problems with my car.....
I think that speedo sensor wire unplugged but it look its plugged..
Will that part could be broken by damage or by kickdown of gas?
zsu is offline
post #6 of 21 (permalink) Old 10-27-2009, 10:48 AM
Yo!
R3DLT1's Avatar
The 4l60E dont have that gear that i am aware of.
R3DLT1 is offline
post #7 of 21 (permalink) Old 10-27-2009, 10:49 AM
chrys95's Avatar
check the electrical connectors that go to your tranny. my 95 Z28 did the exact same thing, lost second, speedo stopped working. all because 2 wires were grounding out. smell your trans fluid. does it smell like burnt popcorn?
Chrys
96 Formula M6- Pacesetter LT's, ORY, Flowmaster exhaust, cc500, AIR/EGR!, 4.10's, Z06 wheels.
Originally Posted by preston View Post
i crouched down and she laid down between my legs rolled over onto her back and just stared at me.
chrys95 is offline
post #8 of 21 (permalink) Old 10-27-2009, 10:53 AM Thread Starter
zsu
zsu's Avatar
I hope that its electrical..
I think that my trans fluid doesnot smell burnt cuz there were no upnormal things of it..
The thing is Speedometer wont work, RPM works other things work too..
I have burnt 3rd gear before but there were nothing about speedometer..
zsu is offline
post #9 of 21 (permalink) Old 10-27-2009, 11:39 AM
chrys95's Avatar
yeah, the plugs tell the trans when to shift and also have something to do with the speedo. mine lost second gear because of it, so if your second gear isnt working I would imagine its probably toasted...
Chrys
chrys95 is offline
post #10 of 21 (permalink) Old 10-27-2009, 01:11 PM Thread Starter
zsu
zsu's Avatar
what you mean with toasted? is it look like electrical or mechanical damage?
zsu is offline
post #11 of 21 (permalink) Old 10-27-2009, 01:12 PM Thread Starter
zsu
zsu's Avatar
And transmission expert said that tow the car do not drive it.. is it harmful for my car to drive slowly to car service? or I must towed my car by a truck? (its a bit difficult for me)
zsu is offline
post #12 of 21 (permalink) Old 10-27-2009, 01:22 PM
chrys95's Avatar
well the electrical problem may have caused second gear to go out, which means its time for a rebuild. in order to make sure the same thing doesnt happen again, you need to find out the cause. I wouldnt drive it if you can help it. I drove my car when 2nd went out but I had the trans completely rebuilt after I found and fixed the electrical problem.
Chrys
chrys95 is offline
post #13 of 21 (permalink) Old 10-27-2009, 02:14 PM Thread Starter
zsu
zsu's Avatar
So you say doesnot take risk and give 50$ for towing?...
I had a close problem like that before.. Speedometer did not work and car had only 1-3rd shift.. After that I got to car service they said the speedsensor has unplugged, they plug it and it returned to normal..
Now Speedometer doesnot work but the cable is plugged..
I hit under of my car and that happens..
zsu is offline
post #14 of 21 (permalink) Old 10-27-2009, 02:43 PM
chrys95's Avatar
its really you're decision. if you dont want to pya for a rebuild, i would pay the $50 and get it towed.
Chrys
chrys95 is offline
post #15 of 21 (permalink) Old 10-27-2009, 03:31 PM Thread Starter
zsu
zsu's Avatar
yeah your are right may be my cars 2-4 band could be burn
zsu is offline
