No gear at all suddenly?! - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 8 (permalink) Old 05-11-2017, 10:28 AM Thread Starter
DirtyBird94's Avatar
I drove my 1994 T/A 5.7l Auto trans to my new house parked it in the garage, backed it out to move it over for the lawn mowers. Then nothing, no gears. No R D 1. When in park the car doesn't move. Any other gear it revs up, and acts like a N. So the linkage is working i think. Any ideas guys?
DirtyBird94 is offline
post #2 of 8 (permalink) Old 05-12-2017, 06:57 AM
Have you checked the trans fluid level?
post #3 of 8 (permalink) Old 05-12-2017, 05:59 PM
Dynamic396's Avatar
Sounds like your pump rotor broke.
Dynamic396 is offline
post #4 of 8 (permalink) Old 05-12-2017, 06:14 PM Thread Starter
Fluid is full and no leaks..whats a pump rotor...the optispark?
post #5 of 8 (permalink) Old 05-12-2017, 06:33 PM
Dynamic396's Avatar
The pump in your transmission. Where is the fluid on the dipstick?
post #6 of 8 (permalink) Old 05-12-2017, 08:06 PM Thread Starter
Uh at idle it's full, with it off its barely on the dipstick. A guy at work said its my torque converter. Are there any dead signs it could be that?
post #7 of 8 (permalink) Old 05-13-2017, 02:03 PM
terminal_crazy's Avatar
You sure? That doesn't sound right.
It should usually be higher with the motor off and drop when running and in gear as it pumps fluid into the torque converter.
Read checking procedure and recheck fluid level. Clean end of dip stick between checks.
Mitch
terminal_crazy is online now
post #8 of 8 (permalink) Old 05-13-2017, 02:09 PM Thread Starter
Ok ill look into that. Thanks mitch
