Headlight bulb replacement - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 11 (permalink) Old 12-14-2013, 05:59 PM Thread Starter
69bu's Avatar
I put a set of black halogen lights in my son's 2000 in the spring. They came as an entire assembly. The driver's side low beam headlight has burned out already. Do I need to replace the whole assembly or can you just replace the bulb itself in these things?
1993 Camaro Z-28 LT1, hot cam, 1.6 scorpion rockers, mid length headers, A4, shift kit, D5 converter, 3.73 gears. M/T drag radials. Best run: 13.191@103.69
Son's car - 2000 Camaro Z-28, LS1, A4, long tube headers, SLP exhaust. Best run: 13.113@107.27 on street tires.
1969 Chevelle, 496, turbo 400, Ford 9", 3.70 gears. ET TBD.
69bu is offline
post #2 of 11 (permalink) Old 12-15-2013, 06:24 AM
The bulb should be replaceable, it's finding someone who has the bulb and holder only that will be the fun part of the mission.
post #3 of 11 (permalink) Old 12-16-2013, 10:45 AM
10 Second Opti Club
sweetbmxrider's Avatar
Should just be a 9006 for the low beam.
sweetbmxrider is offline
post #4 of 11 (permalink) Old 12-25-2013, 05:39 PM Thread Starter
69bu's Avatar
Actually these took a H1 12v55w bulb. Got it swapped out. I am now working on hooking up the halos. I got one side done but lacked all the connections to do the other side. No parts stores open on Christmas.
69bu is offline
post #5 of 11 (permalink) Old 12-25-2013, 08:59 PM
Merry Christmas I have a 2000 Z28 and just wondered if your sons car has been dyno'd if so what results did he get I was thinking of doing long tubes if they are worth it?
marlin1893 is offline
post #6 of 11 (permalink) Old 12-25-2013, 10:04 PM
Don't even question it. Long tubes are ALWAYS worth it. Not just for the power, but for the sound
Xzauhst
1994 Camaro Z28 19x,xxx miles New LT1 and built 4L60E - K&N CAI, Elbow, Air Foil, kooks LT headers, True Duals w/ Dynomax Bullets dumped, 160 stat & fans on early, EGR & AIR delete, EWP, 255FP, ProTrorque 3200 stall, Pcm for Less tune, ET Streets 12.886 @105.12 1.779 60'
Xzauhst is offline
post #7 of 11 (permalink) Old 12-25-2013, 11:35 PM Thread Starter
69bu's Avatar
No it's never been on a dyno. The car did 108 on the quarter mile though. not sure shat the equates to in horsepower? It had headers on it when we got it so I don't have a before and after.
Sent from AutoGuide.com Free App
69bu is offline
post #8 of 11 (permalink) Old 12-26-2013, 10:11 AM
I was just wondering what the hp was on his sons car. I custom made a set of stainless cat replacement pipes for mine and the sound is great with my Maganaflow exhaust. Im running a stock LS1 with just a SLP lid and SLP y-pipe with 139,000 miles we got 321hp and 334tq. Needed to compare to another stock 98-2000 car to see how good that is. Any info would be great as I didnt get a baseline before the light modifications I made.
post #9 of 11 (permalink) Old 12-26-2013, 10:42 AM
10 Second Opti Club
Ah, well that is not stock replacement but glad you got it figured out and partially wired up.
post #10 of 11 (permalink) Old 12-26-2013, 05:20 PM Thread Starter
69bu's Avatar
When all else fails, take the existing bulb out and get the numbers off of it. BTW finished up the other light today. I found a really good YouTube video on how to wire it. Wiring isn't my strong suit.
69bu is offline
post #11 of 11 (permalink) Old 12-29-2013, 04:43 PM
Thanks I will have to wait till spring to take it out I know it gets to 110 in 3rd gear fast we pulled 140 in 4th on the dyno )
