Problems with my firebird! Please help - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
Go Back   LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums > Platform Specific Tech > 4th Gen F-Body
Old 01-09-2013, 12:31 PM   #1
85cutlass user's tech expertise is unknown at this point
Default Problems with my firebird! Please help
Ok I'm new to this forum but iv owned the car for a while. It is a 1994 pontiac firebird 5.7 lt1 with a 6 speed behind it. The Car when driven a long period of time runs fine but if you turn car off and wait about 10min or so then restart car it sputters and backfires. The sputtering and backfiring stops after about a minute or two of driving. Iv had problem for about a week or two now. Originally when this all started the car wouldn't run above 4000 Rpms. The fuel filter was clogged so I replaced it. The problem went away and now I have the problem when hot and you restart it runs like crap. I changed the o2 sensors, fuel filter. Fuel pressure is 40 running. If you can give me any input on what might be the problem I would greatly appreciate it. Thank You Russ
85cutlass is offline
Old 01-09-2013, 04:46 PM   #2
Workman's Avatar
Workman Apprentice Level Tech I
Okay so it sounds like your Opti could be possibly going bad, How many miles are on the car? Or you could just have some trash in the fuel lines thats coming out.
95 Trans am, LT1 V8 , Jasper Transmission A4, Throttle Body bypass, Removed spare tire+Jack, Installed ACR Bucket seats, 118k miles,
Workman is offline
Old 01-09-2013, 05:02 PM   #3
ws6muscle user's tech expertise is unknown at this point
Spark plugs or fried plug wires could cause this too.
ws6muscle is offline
Old 01-09-2013, 05:05 PM   #4
Workman's Avatar
That is true, make sure you check them.
Workman is offline
Old 01-09-2013, 06:55 PM   #5
ICM will also cause problems when hot. You could try the spacer mod to see if it helps.
Mystery Bird is offline
Old 01-09-2013, 08:19 PM   #6
Yo!
R3DLT1's Avatar
My Facebook My Facebook
R3DLT1 Apprentice Level Tech III
Werd. Its easy n cheap.
R3DLT1 is offline
Old 01-10-2013, 05:06 PM   #7
Alright I have a set of plugs I'm going to put in this weekend. The car has 126,000. But the motor was replaced and I'm not exactly sure how many miles are on it. I ran car around yesterday for about a half hour with my scanner hooked up to it. The only code I have on the car in an AC pressure sensor fault, which I don't think that would affect the way the car runs. I was looking at all the sensors while driving, they all look good everything looks in spec, no sensors were lagging. Ill try plugs this weekend and let u guys kno. Thanks also the icm and coil are fairly new, I replaced them maybe a year or so ago.
Old 01-10-2013, 05:54 PM   #8
Never assume parts are good because you replaced them a short time ago. New parts can fail quickly. Since you replaced the icm, did you put heat sink compound on it's back and on heat sink? If no, even a good icm can go bad quickly without the compound on there.
Old 01-10-2013, 10:04 PM   #9
Ya I used dielectric grease
Old 01-10-2013, 10:54 PM   #10
95 Firehawk's Avatar
Not the same thing as thermal compound.
95 Firehawk is offline
Old 01-10-2013, 11:04 PM   #11
Alright ill check that out thanks
Old 01-11-2013, 07:54 AM   #12
Dielectrical grease does not transfer heat, you need to change that ASAP. Thermal grease only.
Old 01-14-2013, 08:30 PM   #13
Alright so I did plugs, and I ended up removing air pump because it was in my way. The car still does the same thing, this time I ran it for a while shut the car off when I got home. Went outside a half hour later and it started sputtering and backfiring. I drove it down the block and it cleared up, now runs fine. Ofcoarse when this happened I didn't have scanner hooked up2 car to see what was going on. Any more ideas
Old 01-19-2013, 10:48 AM   #14
Workman's Avatar
Check that ICM coco knows his stuff lol =] And another thing, Does it run hot??? Like operating wise? At idle how hot does it get, and while driving how hot does it get?
Workman is offline
Old 01-19-2013, 03:41 PM   #15
With the scanner hooked up it runs at like 208 all the time. Idling, driving the highest it goes is 210 degrees
