11-28-2012, 04:40 PM
help putting ls1 in 1997
i am going to take my lt1 out and replace with ls1 383. i heard it is a lot eiser to remove lt1 from bottom. my main question is it eaiser to put the ls1 in from bottom or top? i already have k member for the ls1. i am doing the ls1 carbeurated. thanks for help
11-28-2012, 06:07 PM
It's the same with either engine. I've pulled many and if you have the provisions going through the bottom is the easiest.
11-28-2012, 07:51 PM
Are there any hidden suprises when dropping one out?? I'm fixing to drop one myself
94 Z-28 Camaro 6 Speed, 4:10 richmond, ultimate girdle, k&n cai, msd rotor and cap , 8mm wires, Flowmaster, 160 thermostat, m55A oil pump, cat, air, and egr delete
94 toyota pickup DD
"Its not a hot rod if its got payments"
11-29-2012, 06:56 AM
Not really, just make sure everything is disconnected and if you care about saving the oil pressure switch remove that first because a lot of time it gets busted.
11-29-2012, 07:00 AM
what mystery bird said make sure everything is unhooked i did mine n 3 hrs with a bum shoulder really not that bad
11-29-2012, 08:28 AM
Good write up on removing engine from bottom, unfortunately the site is down. But if you pm me with your e-mail address, I can send the article to you.
11-29-2012, 11:30 AM
Alright thanks for all the help. I'm hoping to have it out and have the new one in and running by the end of next week
94 toyota pickup DD
