Discuss is your convertible hydraulic system leaking, check here - LS1LT1 Forum : LT1, LS1, Camaro, Firebird, Trans Am, Engine Tech Forums
post #1 of 2 (permalink) Old 04-17-2017, 09:04 AM Thread Starter
97z28convt's Avatar
Just wanted to pass along a small nugget of knowledge.
Is your convertible top system leaking fluid? Ive now seen this on two cars and its the only time ive seen these systems leak. Im sure it happens in other places but check here first.. both cars that ive had leaks in this system have come from the brass "t" coming off the side of the convertible top pump on the fender side.. Both cars developed a hairline crack on the bottom of this T.. ive been able to find new "t"s that are slighly shorter than stock but work fine at a forklift supply store for $4 or less. i wasnt able to find an exact replacement anywhere without spending a few hundred on an entire new pump. hope this helps someone at some point.
97 z28 convt, 60k mi. TF heads, 1.6 rr, rods, lifters, comp cam, msd cap rotor coil, full exhaust, Cai, Pcm for less tune , 150 nitrous, no air or egr, tb bypass 3200 stall. 410s. 12.5 spinning on slicks.ugh..
1971 chevelle w ls1 & dakota digital dash, true duals w xpipe, 4whl disc,342s
05 corolla xrs.. one of 5000 made. 00z28convt.
98z28 hard top.. project waiting
89 mustang gt... i know i know..
sold-02 z28 m6, 68 continental sedan, 95TA, 86iroc, 88z28
97z28convt is offline
post #2 of 2 (permalink) Old 04-18-2017, 07:03 AM
Will sticky this thread
